Question about Olympus EVOLT E-500 Digital Camera
CAN'T TURN ON MY CAMERA. PUSH THE POWER BUTTON AND NOTHING. ORIGINALLY STARTED AS WENT TO TAKE A PICTURE WHEN CAMERA CUTOFF, AND HASN'T CAME ON SINCE.
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: power button seems to be pushed down too far --- I can't take any pictures either
Button stuck down! Try removing the battery to see if lack of power will return the button. If that fails take it back to the seller under warranty terms.
Posted on Aug 05, 2007
Camera doesn't turn on
Try to clean the corrosion off the battery contacts. If not give it to Nikon they may be a little expensive but they will restore the camera to it's original condition.
http://www.nikonusa.com/en/Service-And-Support/Nikon-Authorized-Repair-List.page
Jan 11, 2013 | Nikon F3 35mm Film Camera
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
After start button is pushed several low buzzes is heard
Better check that power supply & where it plugs in at out. Also,make sure all the connections are plugged in tight inside. Never assume that a replaced part is good & if you went after-market for the power supply, don't go super cheap. Buy a good one with a good warranty & the same if not more juice than the original.
May 12, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
While shutting down after downloading pictures, I
Try going to this page at the Nikon site, and work from there. You might find your answer if you start here:
http://www.nikon.com/about/news/2004/0128_03.htm
Good luck,
-a.
Apr 01, 2010 | Nikon Coolpix 3200 Digital Camera
Beeps repeatedly, lense won't retract...won't take pictures?
Hi Jeanice21, I just posted the same problem a few minutes ago with my SD400. I followed a few steps of the suggested solutions and here's what worked for me.
1) take apart the front and back by unscrewing the six screws holding the camera together
2) on the left of the flash, there are two little retangular holes with grooved dials in them
3) using a little flat head screwdriver, push up or down to turn the grooves while power up in the movie or capture mode
4) the lens retracted at this point and my camera started working again. Good luck!
Dec 28, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Olympus sp-510uz, power went down and new batteries,
you may gently try to push the lens in, but if you are under 1 yr warranty... i would send to repair
Dec 16, 2008 | Olympus SP-510 UZ Digital Camera
Camera Won't work at all
It sounds defective. Call 800 730 6597.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Oct 07, 2008 | GE A730 Digital Camera
Power button
[I just posted this in another thread. I hope it helps.] My wife brought this camera home from work for me to look at. It had the sunken/broken power button problem.  The T-shaped hinge was broken where it connects to the power button section. I couldn't see any way to glue or repair it that would be strong enough so I came up with an alternate fix.
The actual power switch is below the broken button, just a touch below the "ON/OFF" text. I decided to make a button that pushed the switch directly rather than pivoting like the original.
I needed a push-button shaped object with a shoulder on it (so it wouldn't fall through the hole I was going to drill in the back). I ended up using a small green LED (3mm size I think). I drilled a hole big enough for it to move but not so big it would fall through. I cut the leads off flush with the body and sanded them flat. The hole I drilled lines up with the little bump on the original plastic switch piece.
So I put the LED in place, the original plastic piece over it and added a little bit of self adhesive felt (that you would stick on the bottom of something to protect your furniture) at the top where the silver button is (just to keep the original button from sinking inward). I put the back on the camera and checked that the power button clicked nicely. It did so I put the camera back together and it's as good as new.
And it has a snazzy green power button now.
So if you are handy you can probably fix the camera yourself.
Good luck - Greg
Feb 16, 2008 | HP Photosmart M525 Digital Camera
Cybershot 3.2 seems to work fine until you push button to take photo
when i turn the camera on it says turn the power of and on again and the lens cover will not open
Nov 25, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Power button seems to be pushed down too far --- I can't take any pictures either
Aug 05, 2007 | Olympus FE-230 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
29 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
