Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Chain saw starts and runs once or twice, 3rd time will not start again, spark plug wet - should i replace carburetor?
  • 486 Answers
Most carburetors can be rebuilt and solve most problems, but occasionally the debris is into places where cleaning is not possible, and must be replaced. I would try some basics first though.
Overfuel or 'rich' condition
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Posted on Nov 12, 2009
Doesn't start has spark @ plug fuel @
try starting meaning pull the rope 6 times and then check the spark plug if its wet clean it or try a new plug, if its dry your not getting fuel in the cylinder which means carb problems. if you have a seringe or something to put some gas into the spark plug hole then install spark plug and try it. if it runs for a couple of seconds then you need to focus on the carb. only put a small amount of fuel in the plug hole if you try it otherwise youll be pulling on the rope for awhile before it will start. hope this helps.
Jul 06, 2011 | Echo CS400 18" Chain Saw
I've replace the spark plug, put in fresh gas and tested it for spark. My CS 100 chain saw will not start. Any help would be appreciated.
The spark at the plug (gapped 0.020") should be blue and snappy. If ok, pour a little fuel mix into the plug hole and try for start. If pops several times, then you have fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the primer bulb fills with fuel when pumped several times. If nothing, either the primer is damaged or the carburetor needs cleaning inside. While in the carburetor, inspect the lower chamber diaphragm for hardness or cracking. Go to: www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope that some of this helps!
Oct 23, 2010 | Echo CS400 18" Chain Saw
Starts but dies when warmed up or gas it and choke off dose this couple times then wont start till totaly cold again
Check the fuel filter, air filter, and muffler for plugging. Inspect the fuel lines for decay or damage. Make sure the carburetor fasteners are tight including the carburetor to cylinder mountings. If still not running properly, service the carburetor and rekit if the diaphragm in the lower chamber is hard or cracked. Also, inspect the fuel metering valve that the diaphragm controls. If the tip of the needle is damaged, replace it. Remove the spark plug and check for snappy, blue spark when the saw will not start. Hope this helps!
Jun 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
The chain saw won't start when it is hot
Remove the spark plug to check for spark when it doesn't run. If spark is blue and snappy, pour a little fuel mix into the plug hole, replace the plug, and try to start. If you get a few pops, then concentrate on the fuel system. Check the fuel filter, air cleaner and muffler for any plugging. Check the condition of the fuel lines. Make sure the carburetor fasteners are tight including the ones holding the carburetor to the cylinder. Make sure that you are using fresh fuel with modern synthetic saw oil mixed at 50:1 ratio. Premix the two in it's own can and shake vigorously before filling the saw. If still having a problem, disassemble the carburetor, clean, and re-kit if necessary. Pay particular attention to the lower chamber diaphragm and the fuel metering valve that it controls. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors for great theory and troubleshooting information. Hope this helps!
Jun 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hot chain saw wont start
When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
May 01, 2010 | Garden
Homelite XL 103 chain saw 1967 will not start-
Is this your saw?
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/cc8b1cfa0c6e498d88256c28006444b1?OpenDocument
If this grand old lady were mine I would part with a few $(40±) for a tune up and and maybe an additional $20 if carburetor needs rebuild at my friendly neighborhood Stihl dealer. They perform pressure tests most homeowners cannot. An undetected air leak can destroy your saw. She deserves better.
HTH
Lou
Feb 19, 2010 | Garden
My saw starts good when its cold,but after you run it , it wont start . I have a poulan chain saw 3400
Check the spark with a clean new plug when it won't start. If absent, then the ignition module may be sensitive to heat and need to be replaced. If spark is good, try putting a small quantity of fuel into the plug hole, reinstall the plug, and try to start--if runs for a short time, then you have fuel delivery problems. Check the carburetor for looseness to the engine and the condition of the fuel lines. Check the tightness of the screws in the carburetor end plates. Are you using the choke when restarting? 2-stroke engines usually need a little help to get running even when warm.
Dec 29, 2009 | Garden
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a MAC 3516 chain saw that wont stya running
Check the muffler for plugging of the spark arrestor screen. Go back to original spark plug type. Check the air cleaner. Make sure the chain brake is not dragging in the off position (if equipped). When you had the carburetor apart, did the rubber diaphragm seem stiff? If so, you will need to re-kit the carburetor. It controls the amount of fuel delivered to the jets. Also, make sure the needle valve in the diaphragm chamber is under control.
Aug 20, 2009 | Garden
I can not get my Poulan p4018wt started
Remove the spark plug and look at the inside porcelain--if it is wet with fuel, put the wire back on, lay the base of the plug on engine metal, and pull the starter through while watching for spark. If no spark, try another plug. If still no spark, then something is wrong with the ignition system. Gain access to the ignition coil. Remove the small wire that connects to the coil and try the starter again. If now sparks, the stop switch is probably defective. If still no spark, replace the ignition module. Use card stock to set the clearance between the module poles and the flywheel magnets. Try the starter again--you should have spark by now. Put everything back together and try to start the engine.
If the plug was not wet in the first check and it does spark, then you have fuel problems. Make sure you have fresh fuel in the tank. Check the condition of the fuel line from tank to carburetor. Remove the carburetor and disassemble. If the rubber diaphragm is stiff and cracked, re-kit the carburetor. While it is apart, use spray carburetor cleaner and wash out everything that is metal--don't wash anything rubber or plastic. Blow out all passages with compressed air. Turn both jet screws (H and L) in CW to stops (lightly), then back out CCW 1-1/2 turns each. This should get the saw running. Start with H needle (after engine warms up)--open throttle full speed and turn needle CW until highest speed is reached, but 4-stroking. Engine should immediately smooth out when cutting lightly. Next, run at idle and adjust L needle for smooth idle, but rich enough to allow engine to follow the throttle without gasping. Set idle speed low enough that the chain stops turning.
Hope this gets you running.
Aug 12, 2009 | Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
200 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
