Question about Fantom Vacums XT450K Upright Vacuum
Beater bar won't turn - Fantom Vacums XT450K Upright Vacuum
  • 36 Answers
Could be 1 of 2 things. first try to spin the bar with your finger. "MAKE SURE VACUUM IS NOT PLUGED" "NO POWER TO UNIT" If it does not move, it might be the barrings if not it might just a simple belt replacement. good luck.
Posted on Nov 12, 2009
My Dyson vaccum leaves a row of multiple lines on my plush carpet. I've never had s vaccum leave more than the two wheel lines. I called customer service and they had no solution for me!
It's the beater bar brush. Turn it over and use a screwdriver or knife, and run it the full width of the beater bar to remove the hair and string and other debris that get wound up on the beater bar-NOTE you do NOT have to remove the beater bar or take apart anything. As long as the beater bar spins, and there are no missing sections on the beater bar- this will work. Beater bar could also be worn down- be sure that the bristles extend past the bottom of the vacuum- ALWAYS DO THIS WITH THE POWER OFF
May 03, 2017 | Dyson Vacuums
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Dyson DC17 Beater Bar Won't Work. The beater bar starting to make a very loud grating sound then stopped working. I cleaned the entire area (there are no obstructions) and the belt is OK. The beater...
I'm sorry to hear that you're having difficulties with your DC17's brushbar. If it appears to have jammed completely, it's probably best if you get in touch with us directly so we can help - please call free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
The beater bar will not turn
Hello rebh. Generally when the vacuum beater bar will not turn it is because the belt that turns this beater bar has broken.
That said, most of the dyson's require you to buy a beater bar assembly which includes the belt. Any vacuum cleaner repair shop will have this part. OR go to this link http://www.searspartsdirect.com/partsdirect/brands-products/Dyson-Inc-Parts/Vacuum-Parts
Joe
Thanks for choosing Fixya!
Jan 17, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Fantom Vacums XT450K Upright Vacuum Logo
140 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
