Question about Bernina Artista 180
Is there a way to lower the feed dogs ''a little''?
My machine is a Bernina Activa 220 but it didn't give me that option so I put the Artista 180.
Is there a way to lower the feed dogs ''a little'' on my Bernina Activa 220 to reduce the tension so the top fabric and bottom fabric feed thru more easily together? I'm piecing a quilt top. When I hit an area with a large bulk it pulls and my seams don't line up.
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
Posted on Nov 13, 2009
Bernina artista 200, how do i control the feed dogs?
Not sure what you are asking. The stitch length will determine how far the feed dogs travel (thus pulling the fabric) to create each stitch. There is also the foot (or knee) control that determines the speed that the machine runs.
The page 21 of the manual has that information:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-200
Apr 18, 2017 | Bernina Sewing Machines
The presser foot doesn't sit all the way down in order to sew correctly. Can I adjust it myself? How?
Has that particular presser foot worked in the past? Do the other presser feet work?
If it hasn't been used before, check that it is the correct foot for the machine. Is it perhaps a darning foot or free motion foot? If so, those particular feet are made to Not rest on the feed dogs so that the fabric can be manually moved without the use of the feed dogs.
If none of the presser feet work with the machine, then the needlebar has probably shifted. It may be best to take it for service as it may require specific tools and gauges to adjust it properly.
Presser feet for every purpose
Manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-180
Jun 05, 2016 | Bernina Artista 180
How do I drop the feed on my Bernina 180?
On the right side of the machine is a square button near bottom of machine. Push it in until it stays in. That is the way to lower feed dogs
Feb 18, 2015 | Bernina Artista 180
How do I lower the feed dog on m Bernnia 180
Push in the square button on the right side of machine until it clicks. Then push in again until it u clicks. The feed dogs will raise once the machine starts to sew again
My Bernina 180 will not feed when I use a twin needle on knit fabric.
are you using a stretch twin needle; without one you'll get skipped stitches. However, the feed sounds more like a feed dog issue. Have you lowered the feed dogs for any reason? Will it sew on a woven cotton okay? If yes, but not feeding the knit then you could try turning up the presser foot pressure and see if that helps with the feed.
If you look across the needle plate with the presser foot removed and manually turn it through a stitch sequence, can you see the feed dogs coming up above the needle plate??
Jun 13, 2011 | Bernina Artista 180
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
I have a Bernina Aurora 430 (not on your list). For some reason, the feed dogs have dropped. The button that usually drops them isn't working.
If you remove the metal plate on the bottom of your machine, you can see the workings of the feed dog raise and lower button. With some luck it just might be a screw that came out or it might be a broken spring inside the sewing arm.
Without a service manual or a view of what it should look like inside when it is functioning correctly, at best you would just be guessing. It should be a simple 5 min fix but it is best to take it to a Bernina dealer for proper repair. Good luck, bushvideo
Aug 17, 2008 | Bernina Artista 180
Sewing Machines Logo
285 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
