No power/video..screen test good.Power light amber/orange
I have an Hanns-G Hi221D 22'' LCD monitor. I received it from an client that his computer & monitor was ''supposely'' hit by lighting. When you plug it in or add power all you get is the amber/orange light. I have tested the screen itself which is good and working, I disassembled my 19'' Hanns-G HW191D and connected the video ribbon cable and the 4 inverter tube wire and it work except it only showed in the actual 19'' widescreen view. both fuses are good and not blown. I have replaced several capacitor that I had around, I didn't notice an damaged/leaking/blown caps on the board but I replaced them anyway. If someone can give me an idea where I need to go next I would appreciate it. There's +5V on both outputs to the control board but no power to the inverter tube. Here's an photo of the power board except it doesn't have the audio components (caps, IC w/headtsink, connectors to the right of the large light blue cap).I need some help for what I need to do next. Thanks.
  • 72 Answers
HI,
IF THE VOLTAGES OF INVERTER ARE PERFECT,THEN ITS PROBLEM WITH URS INVERTER POWER ( I C ) JUST TAKE SIMILIAR IC..
THTS IT...
TNKS
RABBANEES
Posted on Nov 12, 2009
Monitor wont stay on
turn off power saving mode on the monitor
Apr 10, 2016 | Hanns.G 22"" hi221dpb dvi widescreen lcd...
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
Hanns g hx191d no picture. My monitor went black while I was working, the green led is lit, I get a picture for a split second when I first turn on the computer or monitor.
The most common cause of this type of display issues is a failure of the back light power supply. There are parts called capacitors that fail and this causes the power supply to not be able to put out the correct voltages to operate the monitor. You cn repair the monitor easily by replacing the bad capacitors on the power supply board. The old ones need to re desoldered and the new ones soldered back in place. You can get a kit of the proper capacitors to do the repair here:
http://www.ccl-la.com/catalog/product_info.php?products_id=194
Nov 02, 2012 | Hanns.G Corporation HW191D 19" LCD Monitor
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
No Signal error on screen. All connections
Do you see a green power light with connected and power on with computer connected ?
If so, remove the connection at the computer video card, you should see a no signal message.
If you do not have a power on lamp, either amber or green, you do not have A/C power to the unit.
Sep 02, 2009 | Acer 22" X223w LCD Monitor
Model HU171D Hanns.G... Monitor is on but blank screen appears...
I think the data wire may be disjoined in the Center. try to replace the data cable and reply me.
Aug 19, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
My Hanns-G hw191d monitor quit coming on. The green light at the side is on, indicating that it is receiving signal from the computer, but nothing displays on the screen. Is there a fix, or should I just...
First, flip the switch for your power surge protector, to see if that resolves. Then, test the monitor on another computer and see if it works. If the monitor still doesn't work, look for another one. Hope that helps.
Jul 06, 2009 | Hannspree HW191D LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Proview 22
try test the LCD to other PC, if it is working on other PCs, then your VGA card might be the cause. And if the same problem happens to other PC's then the LCD is at fault. Remember to Check the VGA cord. Good luck.
Nov 27, 2008 | Computers & Internet
Computers & Internet Logo
255 people viewed this question
David Payne
David Payne
