Upgrading thermostat on Carrier HP packaged 5 ton unit. 38YCBD6D-301 Outside: FB4ANF060 Air Handler: TSTA1CCNAHPO1 Thermostat New T-Stat: Diversitech 675-ts21 Wiring legends do not agree! Old T-Stat used S1 S2 O/W2 R Y/Y2 G C and W/W1 New Stat: Terminal Equipment Wire Y1 1ST HP & AC Yellow G Fan Green W2 1ST stage Furnace White OBW Reverse Valve Orange RH 24v RED Y2 2nd HP & AC Unknown C Common Blue H Humidity Control Unknown DH Dehumididity Control, Variable Fan Unknown RC 24v Unknown I1 & I2 Not Used The A/H does not list any heat installed. Thanks for any help, CLEVE
  • Richard Johnson PE
    Richard Johnson PE May 11, 2010
    s1 and s2 are for the outside air temperature sensor. Not sure if you have one installed. Quck question: Could the model of the air handler be FK4 not FB4? Does this air handler have an electric heating unit installed? As soon as you post the answers, I can post the wiring diragram.
  • 233 Answers
SOURCE: Wiring Trane/Honeywell TH8320U
use the outside designations for heat pump, and inside for standard, I would assume a heat pump since you have more than five wires attached to it now. Use the colors of the wire to match to the designations, use tan for y2, black for w2 rc and rh should already have a factory jumper. I would have to trace out the "U" and see where it terminates, I have not seen a bare wire on a stat in 27 years of doing this. before powering, verify the tan and black at the indoor unit circuit board and see if they are landed on the terminals designated at the stat. hope this helps
Posted on Jul 27, 2009
billyvangogh
  • 108 Answers
SOURCE: Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Posted on Nov 01, 2009
heatman101
  • 43501 Answers
SOURCE: No Auxiliaty heat with new thermostat
The Vision Pro is a great t-stat and I have installed many of them with great results. I am wondering though if it is set up correctly. Did you go in and make sure that it is set for heat pump and for 2 stage heating? Look on the instructions how to get into the advance installer options. Go through that meanu and make sure that everything ig set correctly for your type of heating system and that it is set for 2 stage heating. From what you have here and I can tell the wiring should be okay that is why I think that it is in the t-stat programming.
Posted on Nov 16, 2009
heatman101
  • 43501 Answers
SOURCE: Do not know what color codes of the new thermostat
I can give you a general idea, but unless I know what colors you have and where they are hooked at the furnce/airhandler I am shooting in the dark here.
The R is usually red, the W1 would be white, the Y would be yellow and the G green. in your case where the Y and W1 are together the W2 is probably the white. The X3 is whatever is left over, probably black or blue.
If you shorted the wires you probably tookout a fuse or the transformer in the airhandler/furnace. That will need to be replaced before anything will work.
The R and the X are the ones that you really need to watch that they don't short out, and the R needs to not touch anything metal.
It is best to kill the power to the airhandler/furnace before changing any t-stat then you don't need to worry abut killing anything.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 27, 2009
  • 149 Answers
SOURCE: where does the W2 wire go?
w2 wire is second stage heat does your furnace have two stages.look at gas valve it would have 2 valves/ sol w2 will go to w2 on stat. if a single stage furnace w2 is not used
Posted on Jan 25, 2010
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
Change a thermostat
What brand of T stat are you using?
Feb 25, 2015 | Carrier FB4ANF060 HVAC Electric Unit & AC...
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
Carrier thermostat blank lcd display
Like have a clogged drain and the float switch is tripped. Check the drain line near the indoor unit for a piece with two wires. Remove switch and check for water or look in emergency pan under unit for water. DO NOT LEAVE SWITCH OUT, must vacuum clog free or blow out with compressed air.
Aug 09, 2017 | Carrier Heating & Cooling
Wiring instructions for Thermostat Honeywell with Carrier Package
Jumper R to Rc and hook hot wire from transformer to R usually red wire
O = Reversing valve probably white or orange If you get heat when calling for cool or Vice Versa then switch wire from O to the B terminal.
Y = Contactor usually yellow
G = Blower usally green
Jumper Aux to E need to go to unit and use the wire that goes to your Auxiliary or 2nd stage heat
L = Light if you have this terminal on your unit then hook it up.
C = Common from transformer usually black, if you have this terminal on your unit hook this wire up.
Make sure you go to your unit and only hook these wires up if they go to these locations.
Jan 11, 2010 | Heating & Cooling
New heat pump system freezing, questioning wiring.
W1 and E on stat need tied together. When W1 comes on wire where all heat elements come on. On the outside unit defrost board set the 45-60-90 to 45 and see if that takes care of the frost problem.
Jan 03, 2010 | Heating & Cooling
I have a carrier air/heating unit with pump. It has 8 wires. Brown,blue, white, yellow, green, black, orange,and red. I'm trying to install honeywell thermostat. The wires from my unit are suppose to go...
Turn the power off to the air handler. Open the control cover. Write down what color wires go together at the wiring terminal. All 8 wires are probably not used.
Post the findings here.
In most cases,
E= brown-emergency heat
AUX=white-auxillary heat to supplement HP
Y= yellow-to compressor for heat or cool(hp)
G=green-indoor fan
O-orange-reversing valve on HP when energized in COOL
L=t-stat light(probably not used)
R=red-24v incoming power
B=black-reversing valve on HP when energized in HEAT
C=blue-common wire for 24v
Only one of the "O" or "B" will be used. Not both.
Apr 27, 2009 | Carrier Heating & Cooling
Carrier A/C Intermittent Shut-down Problem
It sounds like there is something in the system that is over heating. A t-stat will either work or it won't there are relays that have 24v coils and can become weak. If your air handler is shutting down it shut down the condenser, if the air handler is staying on but condenser is shuting down check the outside contactor. I am an a/c contractor and can be contacted at 504-722-3946 Eddie.
Sep 29, 2008 | Carrier 38BRC048 Air Conditioner
Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Dec 02, 2007 | Heating & Cooling
Heating & Cooling Logo
294 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
