Question about Kenmore Washing Machines
Washer overflows when loading - Kenmore Washing Machines
  • 612 Answers
It sounds like you have a bad selector switch. This is the switch you set for the size load you are washing. You will want to check the tube that runs from it to the side of the tub. Make sure it does not have a hole in it. If not, you will need to replace the switch.
Posted on Nov 12, 2009
Washer overflowed
What is the model number of the unit?
Nov 28, 2012 | Kenmore Elite 45986 Front Load Washer
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Oct 16, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Overflowed on Large load size
i think the water level sensor tube got filled when you had it on it's side, then after the first spin and drain cycle, the tube was again cleared out and ready for real action.
Oct 29, 2007 | GE WJSR1070A Top Load Washer
Kenmore Elite HE 3T front load washer
Hope this helps ...... F09 is a Overflow Condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check/ Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation PLEASE rate my solution
Oct 04, 2007 | Kenmore 44832 Front Load Washer
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Aug 19, 2007 | Maytag PAV2300 Top Load Washer
Washer overflowing
Clean out the peat trap by the front right side of the machine.
Apr 07, 2007 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
