Question about Homelite Mighty Lite Lawn Trimmer
String trimmer won't start. How do I flush the
String trimmer won't start. How do I flush the fuel?
  • 486 Answers
To flush system
Drain tank, use primer bulb to push out fuel in the lines, refill, use primer to bring in fresh fuel. You may need to pull the rope a few times with the choke on, and then push the primer several times again. Sometimes you may need to put a few drops of fuel into the throat of the carburetor to help it start to fire.
If the problem is severe enough, you may need to remove the carb to disassemble and clean. I have listed a few things to check.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 12, 2009
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
My husqvarna 128ld won't start
Do you have compression, good spark and is fuel getting into the cylinder.?
Oct 21, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Trimmer works sometimes and other times it won't. When it works it is only for a few minutes then it stops like a switch was shut off.
Sounds like fuel issue. Check the fuel line for cracks. Also the diaphrams in the carburetor could be deteriorated due to Ethanol. Soak and rebuild.
Sep 16, 2012 | Toro& Electric String Trimmer
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
STIHL BRUSHCUTTER VERY HARD TO STARTAND WON
Could be a fueling issue, check fuel lined and fuel tank vent. Vents can become damaged and create a vaccum in the fuel tank, stopping the carb from drawing up fuel from the tank.
Jun 07, 2012 | Stihl String Trimmer Brushcutter Service...
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Won't start
drain fuel tank. keep depressing the primer bulb until it is clear. drain tank again. remove carb cover and disconnect lines one at a time. keep depressing primer bulb to get rid of excess gas. remove spark plug an turn engine in a position that the spark plug inlet is facing the floor, pull starter rope a few times to get rid of gas in the engine chamber.
Oct 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
166 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
