Question about LG 32LP1DC 32 in. HDTV LCD
Blown Fuse LG LCD
How do I replace a blown fuse of a 32" LG LCD? There was a power surge and the TV no longer has any power.
Unplug tv and let it set for a couple of hours. Remove the back panel, the fuse is located somewhere near where the power chord comes in. Remove fuse and replace with one of the same rating.
Posted on Mar 31, 2012
  • justin_sgall
    justin_sgall Jan 20, 2013
    MR, JUSTIN, THANK I FOUND OUT THE LOCATION OF FUSE AND I REPLACE ALREADY NEW FUSE, BUT WHEN I TURNED IT ON THE TV, BLOWN AGAIN...??? SOMETHING WRONG WITH THIS??
  • Justin Moore
    Justin Moore Jan 01, 2014
    Something in your power board is drawing too much voltage causing your fuse to blow. Best bet is to replace the board.
  • 11,361 Answers
You should try looking for new power supply module. It may be cheaper that trying to have it fixed. Do you have any pictures. Hope fully the surge did damage the controller board.
Posted on Nov 12, 2009
Tv won't turn on after power surge. Any way to reset a fuse?
Sometimes a power surge will blowout a part inside the tv. If your lucky it could be a fuse which sometimes needs to be soldered to remove and replace. A little experience is required there. A lot of power surges will take out can capacitors on the power board. Some times the board can be replaced or possibly replace some blown caps. Definitely need a TV tech to look at that.
Oct 04, 2015 | Dynex 32 in. LCD Flat-Panel HDTV
Our LG TV will not power on. No light, no sound, nothing. How can we check the fuse on the power supply? Or could it be the power cord?
Hi Dfhamilton,
Damages due to lightening surge can go to any extent in a tv set. If you can, please open the back cover and check the fuse. Replace with the same rating one if you find it blown. Switch on the set. If it works, enjoy watching. If it blows again, please consult some TV tech.
Good Luck.
Aug 17, 2015 | LG 42LE5400 42-Inch 1080p 120Hz LED LCD...
LG 32LD450 TV is completely dead, power supply with blown fuse on primary, how to fix?
Unless you have electronics repair experience, you will need to replace the power supply. If you do have some repair experience, I would check for any shorted diodes, bridge rectifier, switching mosfet, or a cap on the primary side. Replacing the fuse will not solve your problem.
Feb 14, 2013 | LG 32LD450 32 In. LCD HDTV
No power due to thunderstorm, it's off but connected to the power source..
It can be affected due to current surge on the line, the most probable affected area is the power section of your TV. Some incidence are only fuse blown out where you can replace the fuse with a new one just be sure that the rating is the same. But others are major components like MOSFET, Thyristor, Varistor which are usually sensitive on current surge.
May 27, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The green light cimes on but there is no Picture or Sound on my dynex 32'' tv
Sounds like your power supply is shot. Possibly a fuse blown. If its connected to a surge suppressor try plugging it straight into the wall socket.
Feb 28, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Had power surge tv will not work fuse blown or power supply tv is only 3 months old
Hi
This TV should still be under warranty. Most new TV's have electronics warranty of 1 year.
Mar 13, 2010 | Sansui HDLCD3210 32 in. LCD TV
We didnt have a surge protector on our tv we purchased from home shopping net. and lihtning came in the line and i guess hit our tv can it be fixed or is it worth fixing price wise i hate to throw it away...
Look at the power supply module, most of them will have a surge protection devices (called MOV, same as used in common surge power strip but cannot handle big surge that power strip can handle) installed to protect minor surge, it should blow the fuse. Once MOV blown, it will more likely stay short circuit, if you put the new fuse in it will blow the fuse right away. You need to see if the MOVs blew up any sign of blown up components.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Mar 04, 2009 | LG 37LC7D 37 in. LCD HDTV
The tv died
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
LG 32LP1DC 32 in. HDTV LCD Logo
1,682 people viewed this question
Computer Repairing
Computer Repairing
