Question about Nokia N95 Cellular Phone
I cant hear ring tone or voice thro my nokia n95 handset but they can hear me
Nokia 5800 XpressMusic dial tone not coming and auto call on
My suggestion is that you upgrade your software and firmware. A good place to start is the Nokia Download Center. CLICK HERE
Jun 17, 2012 | Nokia 5800 XpressMusic Smartphone
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
One of my handsets is set to silent and i cant remember how to get the ringer back
Because you didn't give your phone's brand and model number just try the below listed tips.
1. Press the # key for 3-5 seconds
2. Make sure that the volume is turned up
3. Go to Menu--Settings--Ring tones--Voice Calls--Select your ring tone--OK
One of these will give you an audible ring.
Jan 08, 2011 | Cell Phones
Cant hear voice when in handset mode
I think the hear piece of your phone is bad. You need to replace it and sometimes the fault could be from the board of the phone.
Best wishes
Nov 16, 2009 | Nokia N95 Cellular Phone
Cant hear caller have to use loudspeaker
what happen to my nokia n95 when i call i cant hear ringing, and i just hear it when they answer already my call?
Jun 08, 2009 | Nokia N95 Smartphone
No tone unless speaker is used.
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
May 22, 2009 | Nokia Consumer Headset
Nokia n95 settings
hi
plz follow thise steps
open
tools then
settings then
general then
personalisation then
tones then
say callers name and chang it to off
i hope that i help u
and if u have any problem u can e mail me
rafatbatran@yahoo.com
Jan 19, 2009 | Nokia N95 Cellular Phone
Nokia N95 Voice tags
i need to say u should save the voice tags in a silent place with keepin the phone at a smalll distance from mouth . say the words cleraly as u are u can repeat the word in the same clarity
Dec 04, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
