Question about Motorola Computers & Internet
Symbol N410, What application can I use to see the scanned data, such as Hyper terminal, Word, excell? I need to validate the outp[ut data, therefore I need to see the data on a specific application, such as Hyper terminal, Word, excell.
  • Official Brand Answer
  • 1,623 Answers
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads for assistance with your barcode scanner.
Mark
Motorola Mobility Support
Posted on Jan 28, 2015
  • 3,100 Answers
Lpzjor
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Posted on Jan 20, 2015
2 Suggested Answers
  • 47 Answers
SOURCE: Symbol barcode scanner N410 makes ringing noise
It's broken....send it in for service. Contact your dealer
Posted on Nov 04, 2009
Excel Corruption files
Without seeing the file, it is difficult to diagnose what is going on, but I will offer some ideas.
What version of Excel are you using? Are you using Excel 2003? Was the file you are trying to open created in Excel 2007 or Excel 2010. If so, it might be using the new format and therefore will not open in Excel 2003 and older.
It is possible the Excel file is data that was imported from a source in which Excel cannot import. Does the Excel spreadsheet contain any imported data?
Try to use: XLSX Viewer Tool here : http://www.xlsx.viewertool.com/
Those are the most likely causes of the corrupt data. Is every file you open in Excel corrupt, or just this one workbook? If it is just this one workbook, then, yes, it sounds like it is corrupted. If every file you open with Excel is corrupt, then your version of Excel could be corrupt, but that is unlikely.
Jul 10, 2015 | Microsoft Excel for PC
Which barcode format does the Symbol N410 read?
The Symbol N410 supports standard EAN/UPC 2d barcodes.
Nov 24, 2014 | Symbol Computers & Internet
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Nov 02, 2010 | Symbol LS2208 Handheld
Hi all i am trying to use barcode scanner in Motorola MC55 Handheld Mobile Computer. i have installed data wedge from...
Hello, Datamatrix is 2D Symbology. Actually this MC55 is a model with 1D Laser Scan engine. The laser cant scan 2D barcodes, therefore he is not decoding the datamatrix barcode.
You would need an MC55 with an 2D Imager or with Camera to scan 2D Barcodes.
Oct 11, 2010 | Motorola MC55 Handheld Mobile Computer PN...
Scan bar code using motorola MC75
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Jul 15, 2010 | Zebra Symbol MC75 Portable Data Collector...
Cannot Get Symbol m2004-i290 cyclone to work with Beetle /M
When connecting to a serial port there are a couple of things that could be causing the issue. The biggest problems are usually one of these:
  1. The app does not accept serial data.
  2. The RS-232 settings of the scanner and serial application do not match.
  3. The cable issue.
  4. The data is not using the termination character the application needs.
Are you using a Symbol 25-32465-20 or CBA-R01-S07PAR cable?
If so, do you know for sure your application accepts serial data? The scanner puts the data on the COM port and the application takes it from there. A good test is to try the scanner in Hyper Terminal if you have it. It is usually listed under: Programs>Accessories>Communications.
The M2004 series scanners default to 9600 baud (or bits per second), 8 data bits, 1 stop bit, no parity and no hardware or software flow control.
When starting HyperTerminal you may have to go through a screen that asks for a phone number. Just enter something and click OK to get to the next screen (sorry I can not remember exactly what that screen looks like- once it is set you do not see it again.) Next will be the Connection Description window. You will name the session (name it anything you would like) then click OK. Next is the Connect To box. Select your COM port in the Connect Using box, the first three boxes do not matter. When you click OK a Properties window will open. Most likely you will only have to change the Bits per second to 9600 and the Flow control to None. When you click OK your session should be active. You will have a blinking cursor in the upper left corner and in the bottom left portion of the window you should see the session time counting up. You can now try to scan a barcode. If the data shows up you know the scanner and cable are both working.
If you know your application accepts serial data (Word, Notepad, Excel do not) then it may be the application needs to see a carriage return at the end of the data. The CR is added by scanning Scan Options, Data Suffix, Enter from the M2000 Series Product Reference Guide. Test the scanner. If you still do not get data scan Scan Suffix, 1,0,1,3. Again all of these barcodes are in the M2000 PRG which can be obtained here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969606apdf&sliceId=&dialogID=116516744&stateId=0%200%2011867900
Hopefully this information will be helpful in getting the M2004 working.
Jul 24, 2009 | Symbol M2004 Barcode Scanner
Symbol PDT 6846 - Scanner won't read 13 digit barcodes (program returns "not on file"). How do we update the scanner application?
This sounds like a programming issue. What application are you using? If you are using a terminal emulation software then you will need to check your host for the issue. If you are using a batch program where the files are stored on the scanner then you will need to check your "validation" files to make sure the code you are scanning is in the scanner.
Jun 29, 2009 | Symbol PDT 6846 Portable Terminal
Stuck in d mode needs to be in c mode
You cannot access C: Drive as this is the eprom of the device and is not accessible. If it shouws the D: prompt it is because it has no applications loaded. Let me know exactly what do you want to do and i will help you.
Apr 28, 2009 | Symbol PDT 6846 Portable Terminal
Symbol MC3090
Yes, this is possible. You could use the ADF rules in the scanning application called DataWedge. This application is available at support.symbol.com
Mar 14, 2008 | Symbol MC3090 Mobile Computer
Computers & Internet Logo
1,108 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
