Question about Polycom Soundstation IP 7000 Conference Phone - PoE and AC Adapter
Polycom IP 7000 error code 0x4D2D
Trying to connect this to a trixbox. installed the polycom bundle on the server and added the phone in the endpoint manager. (IP 7000 not supported) but in trixbox forum they said IP 650 setting would work. was making progress, then all i get now is error code. cleared out memory and restarted, still get error. wont even finish booting.
  • 3 Answers
SOURCE: Not able to getting video from Remote far end.
Is the Indian site within the firewall? If so, I would focus on the firewall. Does the US site have a firewall? They may be blocking outbound traffic. If you are connecting but no video, it sounds like UDP traffic is still being blocked somewhere. If you can, you may want to assign public IPs on the units and test outside of the firewall.
Hope this helps..
Posted on Jul 23, 2008
SOURCE: polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
Posted on Feb 08, 2009
SOURCE: forgot the polycom VSX 7000 password - how to reset
The polycom didn't allow for numbers, only letters.....
How do I do password recovery in this case?
Posted on Mar 30, 2009
  • 10 Answers
SOURCE: Can not able to dial out any number from Polycom VSX 7000.
Check out the following things:-
1. When dialing a ISDN number, be sure that the call preference has not been set to IP H.323 on the home screen just below the dialing field.
2. Check with your service provider that outwards dialling have been enabled on the lines provided to you.
Posted on Apr 02, 2009
ajaybcd
  • 7 Answers
SOURCE: I have polycom 7000 with
Verify the uplink / download bandwidthon the broadband link.Broadband link do not have symmetrical upstream/downstream speeds. Perform test to verify.
Try non-peak hrs.
Check if latency is consistent.
Posted on Oct 14, 2010
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
Mar 28, 2011 | Polycom SOUNDPOINT IP 301 SIP
We tried to put factory default in Polycom IP 331 SIP Phone.It is booting continuously and it shows the following error while booting."Error loading 0004f2329caf. cfg". All the other booting...
I answered this question for another user:
http://www.fixya.com/support/t8134583-coult_not_using_boot_server_error
This occurs when the phone is set up to load it's configuration file from a ftp or tftp server and it cannot find the file or server location. If the phone is supposed to do this, please check that the ftp or tftp service is running on the specified server. The server name or ip is specified in the setup of the phone, available when the phone is first booting up. The default username is 'Polycom' and password is '456'. If you DO NOT want your phone to get it's configuration from a network server, enter the setup area and remove the server name or IP address from the appropriate section.
Jan 04, 2011 | Polycom SoundPoint IP 331 IP Phone
I have polycom 7000 with release version of 9.0.1 and second party having Polycom unit of 700 with release version now i am facing the poor video quality while connecting. Bandwidth at another end where...
Try non-peak hrs.
Oct 14, 2010 | Polycom VSX 7000 Video Conference
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
Polycom IP 330 SIP C Will not boot up
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Dec 16, 2008 | Polycom SoundPoint 330 IP Phone
Polycom ip501f error, application is not present
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
Dec 04, 2008 | Polycom SoundPoint IP 501 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Polcom phones stop ringing
go to this website and go to customer support www.polycom.com
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom Soundstation IP 7000 Conference Phone - PoE and AC Adapter  Logo
110 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
