Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Can you switch the way the door opens on a Sub Zero 650?
  • 441 Answers
NOPE, Sub-Z needs to be ordered that way
Posted on Nov 12, 2009
How to open sub-zero 650 condensor cover ?
The cover has 3 bolts, open refer unit door, in the ledge of the box just above the door, you will/should fined 3 screws. Remove them and tip the panel toward you slowly, release the two springs and remove panel. Good Luck
Aug 01, 2014 | Sub-Zero 650 / O Bottom Freezer...
My sub-zero 650 fridge beeps when the door is open for awhile
It is a warning signal, it can't peep the temperature as low as wanted.
Jul 18, 2014 | Sub-Zero 650 / O Bottom Freezer...
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Door slow closing sub zero 650
The door cams are worn under that door, this unit takes two, one for the door, the other for the hinge. They are different too.
Good Luck
Jan 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
Closing and opening a sub zero door
Maybe I'm not understanding your question completely.. You can open the doors whenever you want - as often as you like. The doors are no different than any other fridge as far as how often you can open and close them. Please clarify if I missed your intent. Thanks!
Jun 17, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 650 - Light doesn't go on
It's either a new bulb needed or a new door switch. Try the bulb first as it's cheaper.
Sep 28, 2009 | Sub-Zero 650 / O Bottom Freezer...
How do you tighten a loose handle of the fridge door? Sub zero 642
I have the Sub Zero 650. I am not sure if yours iworks same but what you do is use a 3/32 Allen wrench; as you push the handle into the screw on the door so that it is flush, you insert the Allen wrench in the hole at the bottom of the short vertical connector at top and tighten; repeat for upper or lower part of handle.
Aug 15, 2009 | Sub-Zero 642
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Light is out in 650
Check continuity on door light switch with ohmmeter (turn off power and disconnect wire harness at switch first) Probably a second switch that turns compressor off if door open. my 690 sub zero had a bad light switch that was stuck on initially but now only works if I wiggle it. Can a person buy parts online? Some new subzeros have a fuse panel behind the compressor grill??
Just bought a used 690 and found a nice wiring diagram for a model 630 or something in a nice ziplock pouch behind the compressor grill. Look there for clues.
May 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
88 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
