Question about Frigidaire GLEQ2152ES Electric Dryer
My electric frigidaire dryer has stopped turning and will over heat. what could be the problem?
  • 236 Answers
The belt driveing the drum has probably broken. The tumble action is essential to proper and safe drying of clothing. It will need to be replaced.
Posted on Nov 12, 2009
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The coils in back turn red hot and smells like it is burning
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
Aug 15, 2011 | Frigidaire FER311FS Electric Dryer
My Frigidaire Crown electric dryer isn't heating. The drum turns but no heat! HELP!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Frigidaire GLER341A Electric Dryer
Frigidaire gallery series , stop every 10 min. flashing ap , no heat .
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire gallery heats up but after a few minuts stops
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire FSG748GF Dryer
My frigidaire gallery model fsg748gfs gas dryer starts to heat up but stops after a few minutes?
heatman101
Aug 22, 2010 | Frigidaire FGQ332ES Gas Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dryer not going to full heat
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug
Nov 15, 2007 | Frigidaire GLER642A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
96 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
