Question about Dell P1500 Laser Printer
Several pieces of paper feed at once causing printer jam
    Master:
  • Dell Master
  • 956 Answers
Clear jam, if not already done so.
Cheap paper will and does cause jams a lot, like me spend a little more for quality. Not too much!
When placing in tray hold amount of paper in your hands and twist and wiggle, this has the effect of seperating the paper sheets that and do stick together. The more wriggling the better chances of paper running free. But rem, jams do happen even with better grades of paper.
Finally, have a good look at the front of the printer rollers for tiny bits of paper that you might not at first to see?
Posted on Nov 12, 2009
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Lexmark C710 MFP jams 200.04
Things to try:
1. Look for a piece of paper jammed in the rollers. 95% of the time that is what it is.
2. You have a paperclip or paper wad in a feed roller or gear.
3. The hard and easy way to find the jam is to feed a piece of paper and then before it feeds all the way through unplug power to the machine about the time where it usually jams.(several times may be necessary) Then follow the piece of paper to where it jams to find the location of the clogged paper.
Sep 15, 2009 | Lexmark Optra C710 Laser Printer
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
alternative :
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
Dell P1500 Laser Printer Logo
250 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
