Question about Cell Phones
I ENTERED THE OTKSL 4 TIMES AND NOW THEY WANT THE SPC
Panasonis u13 code
Add Toner 1. Toner Bottle is incorrectly installed.
2. Low Toner.
3. Toner Sensor is disconnected.
4. Toner Sensor is defective.
5. SPC PCB connector is disconnected.
6. SPC PCB is defective.
Mar 17, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
Cannot print
E5- 11 Printer Engine Communication
Abnormal
1. SPC PCB connector disconnected.
2. SPC PCB defective.
3. SC PCB connector disconnected.
4. SC PCB defective.
Nov 18, 2013 | Panasonic DP-8016P Copier
I need a reset code for phone screen locked
There's no hard reset on this phone. Here's what you want to do. If your phone is currently locked on your home screen pres 111111(do not press unlock because it'll only give your 4 spaces, just do it until you see the 1's appear). You should see Options or Service appear,if Options, select options then service, if service select service. You should see reset lock, select it then click yes. It'll ask you for a 6-digit code. This is called the 6-digit service programming code or SPC, just call MetroPCS' customer support and have them give you the SPC, once you've entered it, your phone's lock code will reset to 0000 or the last four digits of your phone number. If it'snot locked it'll be easier for you to enter 111111 on the home screen. Follow the same procedure.
Aug 28, 2013 | Kyocera wild card Cellular Phone
HOW TO OPENLINE HITACHI CDMA W42H???
All type of phones (old modeles):
NAM programming: 47*869#08#9
Test mode: *759#813580 or 5809540*45680
exit test mode - 02
A-Key: menu + 0, code 25##
Samsung A500
1. Enter ## and the 6 digit OTKSL
2. SERVICE MENU will appear and 1.Basic will be highlighted
3. Press OK
4. Device will display NAM CDMA/ Phone Number
5. Enter 10 digit MIN
6. Press OK (3 times)
7. Display will return to Service Menu. Press END.
8. Programming is complete
Samsung N240 and N400
1. Enter ## and type in the 6 digit OTKSL
2. The display will show SVC MENU and 1. Phone Number
3. Press OK
4. Enter the 10 digit MIN and press OK
5. The display will show NAM with Home SID on the second line (Note: SID is no longer used)
6. Press OK
7. The display will return to the SVC MENU
8. Press END to complete the programming
Samsung Uproar
1. Press MENU key
2. Enter 9 2 0
3. Enter the OTKSL
4. At SVC Menu screen press OK
5. Enter MIN and press OK 4 times
6. Enter SID (4654) and press OK
7. Press END key
Samsung N300
1. Press ## followed by the OTKSL
2. SVC menu will be displayed
3. Press 1 for Phone #
5. MIN that was entered will be displayed press OK
6. SVC Menu will display press 3 for NAM
7. Enter the 4 digit Home SID press OK
8. Press END and handset will power cycle
Samsung i300
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. ENTER OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
Samsung A400 and A460
1. Enter ## and OTKSL
2. Press 1 for Basic at MENU (1 of Phone # when using the MSL)
3. Enter 10 digit MIN and press OK
4. At 1.Basic Menu press the END key
5. Handset will power cycle
Samsung 3500 8500 6100 N200
1. Press MENU
2. Press 6 0 (3500) 8 2 0 (8500/6100/N200)
3. Enter OTKSL
4. Press 1 at SVC MENU Screen
6. Press OK 4 times
7. Enter SID (4654) and press OK
8. Press END key
9. Programming is complete
Qualcomm:
QCP-800 programming: menu + 3 + 0.
SPC: "000000" or may be other SPC typed by user.
QCP-820/1920/2035: type "111111" and press Jog Dial.
Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user.
QCP 1960 and 2760
1. Press softkey under the work MENU
2. Press 8 0
3. Enter the OTKSL
4. Press softkey for OK
5. Enter MIN and press softkey for OK
6. No SID is require for this handset
7. Press softkey for EXIT
LG:
LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user
A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key
LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user.
A-Key: type 2539** and enter A-key
LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user.
LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user.
LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200
1. Press ##
2. Enter the OTKSL
3. Scroll to SAVE and press OK
4. Scroll to MIN and press OK
5. Enter 10 digit MIN scroll to SAVE and press OK
6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete)
7. Enter SID (4654) and scroll to SAVE and press OK
LG5350
1. Enter ## and enter the OTKSL and press the left soft key under the word clear.gif
Mar 01, 2012 | Cell Phones
How to use RecZone password vault to change from alphabetical to numberical
on the reczone password vault you can enter numbers. on the button with 1@/.:, if you press the button once you will see @ entered. press the button 2 times quickly to enter a /. press the button 3 times quickly to enter a . press the button 4 times quickly to enter a :. press the button 5 times quickly to enter the number 1. press the next button 4 times quickly to enter a number 2. press the next button 4 times quickly to enter a number 3. press the next button 4 times quickly to enter a number 4. press the next button 4 times quickly to enter a number 5. bottom row: press the first button 4 times quickly to enter a number 6, the next button 5 times quickly to get a number 7, the enxt button 4 times quickly to get the number 8, the next button 5 times quickly to get the number 9, and the last button on the bottom row press it 4 times quickly to enter a number 0. pressing caps lock does NOT switch it from alpha to numeric mode. caps lock only gets the letters entered in UPPERCASE.
Nov 30, 2011 | Computers & Internet
Error E04-01 Panasonic DP-4510
E4- 01
Fuser Warm-up Temperature
Possible Cause(s)
1. Fuser Thermistor dirty.
2. Thermistor position incorrect.
3. Thermistor defective.
4. Thermistor connector disconnected.
5. Fuser Lamp connector disconnected.
6. Fuser Lamp defective.
7. Fuser Thermostat defective.
8. Thermal Fuse defective.
9. SPC PCB connector disconnected.
10. SPC PCB defective.
11. Fuser temperature low. (Adjust F6-31)
12. Incorrect SC PCB is installed.
13. Incorrect SPC PCB is installed.
Aug 05, 2011 | Panasonic FP-D355DC Copier
My phone dont work because of otksl
OTKSL = One Time Key Subsidy Lock
usually happen if we input wrong SIM card or card from other provider. You need to unlock the phone
Mar 10, 2011 | LG Rumor 2 Cell Phone
I have philips spc 900nc/00 wev came but dont have driver softwere so can i download this driver softwere
http://www.downloadatoz.com/driver/item_philips-webcam-spc900nc-37-driver-r5b-windows-xp-english.html
try this one ...I sow that its almost the same ...maybe you didnt write the lot no right ...its a spc 900 NC ....but its has a 27 in the tail...Good luck !
Apr 18, 2009 | Philips SPC 900NC Webcam
Cell Phones Logo
187 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
