Question about Husqvarna Garden
I tried to start my mower, and it turned over and over. I stopped for about 2-3 minutes and tried again and it would not turn over. The battery is charged (new) and I checked the fuses (only found 2). When the key is turned to the auxilary postion, it does make a clicking sound but nothing when turned all the way
  • 486 Answers
Sounds like you ran the battery down, charge or jump it with an automobile. But now, you need to find why it did not start.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) fuel lines and tank filter
3) check choke linkages to make sure choke is fully applied
4) check fuel solenoid (on the bottom or side of the carb) to make sure it is being activated. This will make a small click when key is turned on. It has a small plunger that uncovers the main jet, so it could be plugged.
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) check and clean main jet ( normally is the bottom bolt holding the bowl onto the carb
Posted on Nov 12, 2009
Engine was running OK when it started to slow down and finally stopped after about 1 minute. Wouldn't start again.
did you set up the engine or does it turn freely?
clean out fuel system drain gas and clean carb
Sep 27, 2015 | Garden
I have a PoulanPro 18hp (Electrolux) Riding Mower..got a new battery and it tries to turn but hits that spot on rotation that stops it..then it has to begin the rev. over again.HELP( it shaft bent?)
If it's hard to turn with the plug out I think you answered your own question.Strip it down and have a look. Perhaps a valve stuck down?
Jul 15, 2014 | Poulan Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Craftsman gt 5000 blades quit turning
is there a wiring rubbing on metal?is a safety switch failing?
Apr 16, 2012 | Craftsman Garden
19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Jul 15, 2010 | kawasaki Garden
Craftsman 15.5 h.p. riding mower won't start
Try this,follow the positive battery to the part it's attached to,that's what is bad,remove it and take to Lowe's,they have one and it's not expensive.
Jun 21, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
106 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
