Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pen drive is blinking to get formatted but doesnt show or allow me to see my files and edit it
    Master:
  • 956 Answers
Have you assessed, my computer, does icon show up for pen drive?
If so right click open search then when finished orsave to another location, click format?
Posted on Nov 12, 2009
I cannot format my trancend pendrive and it has contents but its not showing ? watto do?
Either your file system is corrupted or your pen drive could be damaged.
Assuming it's not a hardware issue, you can try the following
  • Download EASEUS Partition Master 7.0.1 Home Edition (it's free) from the following link
http://download.cnet.com/Easeus-Partition-Master-Home-Edition/3000-2248_4-10863346.html
  • After installing it, connect your pen drive and open EASEUS Partition Master 7.0.1 Home Edition
  • If your pen drive is not damaged, it should show up in this list.
  • Right click on the pen drive and choose format.
  • If format is not available, choose delete
  • If you choose delete, then right click and choose create partition.
  • Then choose the apply button on the top left
Warning : Use extreme caution when using partition manager, make sure you don't select any of your hard drives by mistake or you could lose all your data.
Let me know if you need any clarifications
Regards
Glen
Mar 01, 2011 | Office Equipment & Supplies
I have put my sandisk memory card of 2 gb in computer,and it says the file is not formatted,and when i format it it says windows is unable to format and file doesnt open...plz help me on this
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chip corruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
Dec 27, 2010 | SanDisk 2GB microSD Memory Card
After charging and turning my swimp3 player on, the green light starts blinking and no music is played. How do i solve this problem?
my pen drive was inside overload files the system one message cammed Yes or No asked i am pressed yes thats way the pen drive was " 0" files showing not formating that files imp help me
Dec 23, 2010 | Audio Players & Recorders
My pn drive shows used space & free space is
see if you can format it if not it is bad
Apr 13, 2010 | Transcend (589307) Media
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to unlock my 2 gb pendrive
first backup all your data..then try formatting from command prompt by typing format x: where x: is your pen drive... if that doesnt work,try the mformat utility available here http://www.4shared.com/file/64277329/48498e3c/mFormat.html
Jul 16, 2009 | Pen Drive IVO MP3 Player
My pen drive cannot formated,and when i go to format, it displays message as drive is write protected cannot format the drive,, please solve problem
Hi, Make sure you do not have any read only files in the pendrive or system files which may not allow the pen drive to be formatted. Turn on show hidden files and check too. Change the properties of the files which are read only and then u must be able to format it. Also do check if the pen drive can be password protected. Since some pendrives in the market do have this feature. Feel free to post again if the problem persists
Jul 08, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
MY KINGSTON 2GB pen drive shows zero spacing......
do you still have warranty for the Pen drive, suggest you take it to the shop you bought it. you seem to have got a defective ped drive. also if you have the serial numbers, check online with Kingston to see if you have got a genuine kingston product.
Feb 02, 2009 | Electronics - Others
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
82 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
