Question about Garden
Can't Find Mower Housing
Rusted out housing 48173
  • Roland W VanLue
    Roland W VanLue May 11, 2010
    what is this number? brand, model numbers from ID tag?
SOURCE: I have an american commander cartridge type filter
Go to this web site http://www.poolcenter.com/parts_filter_american_products_commander.htm
Posted on Nov 30, 2010
Consistant
  • 61 Answers
SOURCE: Pipe from the water pump
Very common on chry. vehicles. This is known as the "coolant transfer pipe" and is available from the dealer.
Posted on Mar 24, 2011
BAMOUT
  • 2478 Answers
SOURCE: trying to find mandrel housing and spindle for poulan riding mower model 15538b which they no longer make so who's parts would be the same the mandrel housing is a three bolt not 4
Order part no. 128774. My poulan mower takes the same mandrel as your.
Posted on Mar 05, 2012
dustydis
  • 373 Answers
SOURCE: How to remove rusted fill plug on the rear housing differential
try liquid wrench spray and let it soak for a few and try is works it come in a can like WD40
Posted on Sep 22, 2012
  • 100 Answers
SOURCE: my husqvarna is 17mos old and the rear mower brackts (one) has broken off the housing is it covered under the term non-expendable componet?considered ( is brok r
take it to a weldin shop
Posted on Oct 27, 2012
Sequence for replacing starter cord
remove housing from mower. pull rope as far out as possible and hold with vise grips then put new rope on remove vise grips and let spring wind rope in replace housing on mower .
May 11, 2015 | Garden
Have a 2-4 hp lawnmower where the rewind spring and rope was broke. Have put new spring and rope on-works great in housing. When attach it to lawnmower the rope pulls out but won't retract back in. As soon...
When you remove the recoil shroud ( housing ), the square shaft sticking out should move freely in a counter-clockwise direction and you should hear clicks when you twist. If you don't hear the little balls clicking or the square shaft doesn't move freely counterclockwise, then that square shaft is rusted onto the end of the crankshaft and must be freed before it can be removed. This is a common problem for mowers left out in the elements. Sounds like the shaft is frozen onto the crankshaft end. Procedure: First, disconnect the spark plug. Get a magnet ready because 5 little balls are gonna come rolling out on this upcoming move. Take a 1/4
Sep 27, 2013 | Briggs & Stratton Briggs Stratton...
I have rusted and worn pulley on my mower deck. I have new pulleys. How do I remove the old ones to install the new ones?
How do they install on to the deck.If they are splined with a bolt holding them then remove the bolt.Sometimes the housing bolts to the frame of the deck with 3 or 4 bolts.Clean the deck and area to be worked on real good and see what kind of hardware is holding it to the deck.Hope this helps.
Nov 05, 2012 | Husqvarna Garden
Pull cord want retract so i can start mower got plastic cover off but the cord is in medal housing which is held down with three rivets how do i get it off to fix cord.
You have to remove the motor cover that the starter housing is riveted to. Usually three or four bolts around the perimiter of the housing and it will slide off with the starter housing.
May 05, 2011 | Mtd 22" Yard Machine Push Mower
Hi, I have a Samsung DLP HLR5667WAX. My bulb just blew and it says it's a L620 BP61-01025A. I can't seem to find this bulb anywhere, does anyone know if the holder plus housing lamp is listed under a...
Hi,You won't be able to find that part # because its not a correct part # it's just one of the #s you can find on the housing.Your part # is BP9600826A and samsung was either putting a small and square lamp or big and round.You will need to pull it out and check which one you need.If you don't want to get lamp by itself simply buy it w the housing and it won't matter which one you get.You can find it here: http://www.discount-merchant.com/Samsung-BP96-00826A-Lamp-Enclosure-p/samsung-bp96-00826a-lamp-enc.htm?Click=48173
Apr 08, 2010 | Televison & Video
LOOKING FOR RELIABLE REPLACMENT LAMP ASSEMBLY AT REASONABLE COST
Hi, your part # will be 915p020010. The original maker is Osram which last around 4000 hrs. You can get the Philips which last 6000-8000 hrs with a superior picture quality,only if you have the housing that has a white cart board covering the back of the lamp.If your housing is complete plastic you will have to get the original Osram. Here's the link where I found it: http://cgi.ebay.com/915P020010-LAMP-FOR-MITSUBISHI-TV-915P02A010-BY-PHILIPS_W0QQitemZ330390868795QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cecd4933b?Click=48173
Jan 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Pull rope snapped on my Yard Machines 4hp 22in push mower
There should be 3 -3/8 or 7/16" bolts on the side of mower (where the spark plug is, there should be one) the other two will be just opposit of the two. Remove bolts and housing should be free.You might to remove any cables to free up any slack.
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
