Scaner no function ccble check alarm replesed
Scaner no function (cable check alarm) repleced 3cables no joy
Replese sefety pin
What the hell is a " Sefety Pin " and why would you want to replese it for ? ?
Jan 10, 2018 | Computers & Internet
Eror scaner in samsung laser printer cx 4300
  1. check scanner cable.
  2. check scanner home position sensor
  3. check belt
  4. replace scanner motor
  5. main board
Jul 25, 2015 | Samsung Office Equipment & Supplies
All lights and gages working press to start nothing have had bike dissmanled for 3 month all plunge off I have taken out my alarm still no joy
Did you check the battery? Take it out and take it to a Autozone or something and get it load tested.
Mar 28, 2014 | 2011 Suzuki GSX650F
I can not align my cartridges on my HP F2420. When i print the test page , only the colored lines appear , nu black on the paper , and when i put that printer test page in the scaner it says ''Aligment...
The black cartridge needs to be replaced.
The printer requires the black as well as the color cartridge to be working
in order for it to align correctly
Feb 15, 2011 | Office Equipment & Supplies
MP160 canon printer. Flashes "E" then "4" then "2" on screen. The "alarm" light is flashing too. No paper jammed. powered on/off. Reinserted ink cartridges. Problem remains. Thank you. From Mel
This error means that you have scaner trouble, most likely the scaner is stucked, or the main logic pcb is faulty.
Try to remove copy glass and manually walk the scaner few times and put him in left position, grease it.
If doesnt help, the best way is to buy new printer.Logic board is too expensive for repair.
Hope that helped
Jul 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Timex Alarm Clock Radio Isn't Functioning
Is it electric or battery operated? Check cables and battery.
Sep 25, 2009 | Timex Clock Radio with Dual Alarm for...
Epson cx3200
If it can print from the printers stand alone function....
1.) check on cable connections > transfer usb cable to a diff usb port > use a diff usb cable
2.) check on printer driver >
cancel pending documents > Control Panel / Printer and Fax ( for windows systems )
Whats the OS on your Computer?
Mar 20, 2009 | Epson Stylus CX3200 All-In-One InkJet...
14 people viewed this question
k24674
jasbo
jasbo
