Maxtor hard drive jumper setting for model 6v200e0
Need to know maxtor hard drive jumper setting for model 6v200e0 (Serial ATA)
    President:
  • 2,600 Answers
here is a poster of Maxtors jumper settings for each kind of drive.
Posted on Nov 12, 2009
  • 323 Answers
Serial ATA drives don't need master/slave jumpers. You can choose "computer select". In fact, you should be a ble to run an ATA drive with no jumper. When you enter set up, it should automatically be recognized with the right bios version.
    Sniper:
  • 107 Answers
PLEASE NOTE: Unlike standard ATA
Advanced Technology Attachment. ATA is the most common interface used in consumer and corporate PCs today because of its lower cost and very favorable performance. ATA is also known as IDE (Integrated Drive Electronics) in the hard disk drive industry.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()">ATA
drives, Serial ATA drives DO NOT require the use of jumpers to configure the drive. Please disregard any references to jumper settings and Master
A Parallel ATA drive controller can support up to two drives. A drive designated as the Master drive means that it is the primary drive on the controller. This is the drive that is usually used to contain the operating system for the computer. The slave drive is usually an additional drive in a computer used to storage additional data. A drive usually uses jumpers to tell the computer whether it is the master or slave. Jumpers are small plastic pieces that fit on metal pins on the back of a hard drive and completes a circuit. PATA controllers support up to 2 drives per cable. Most PATA drives contain a Cable Select jumper setting which means that if the drive is connected to the end of the cable, it is the Master. If it is placed in the middle of the cable, it is then designated the Slave.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()">Master
, Slave
A Parallel ATA drive controller can support up to two drives. A drive designated as the Master drive means that it is the primary drive on the controller. This is the drive that is usually used to contain the operating system for the computer. The slave drive is usually an additional drive in a computer used to storage additional data. A drive usually uses jumpers to tell the computer whether it is the master or slave. Jumpers are small plastic pieces that fit on metal pins on the back of a hard drive and completes a circuit. PATA controllers support up to 2 drives per cable. Most PATA drives contain a Cable Select jumper setting which means that if the drive is connected to the end of the cable, it is the Master. If it is placed in the middle of the cable, it is then designated the Slave.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()">Slave
and Cable Select
A Parallel ATA drive controller can support up to two drives. A drive designated as the Master drive means that it is the primary drive on the controller. This is the drive that is usually used to contain the operating system for the computer. The slave drive is usually an additional drive in a computer used to storage additional data. A drive usually uses jumpers to tell the computer whether it is the master or slave. Jumpers are small plastic pieces that fit on metal pins on the back of a hard drive and completes a circuit. PATA controllers support up to 2 drives per cable. Most PATA drives contain a Cable Select jumper setting which means that if the drive is connected to the end of the cable, it is the Master. If it is placed in the middle of the cable, it is then designated the Slave.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()">Cable Select
configurations in the Maxtor Installation Guide.
This was taken Directly from the installation manual!
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
How to set jumper to slave mode on maxtor 6y080m0(picture pls)
These are the jumper settings for a Maxtor Diamond Max ATA hard drive.
Sep 23, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I want to install as second drive - i need the jumper settings
There should be a diagram on the front of your drive at the top left that shows you the jumper configs.  For most Maxtor drives, if you want a drive to be slave, you remove all jumpers.
Cheers!
May 01, 2009 | Maxtor Ultra hard drive kit 80GB 7,200 RPM...
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Need installation instructions for Maxtor 80 GB 7200 RPM Ultra ATA/133 8 MB Cache Hard drive for compaq presario sr1630nx microsoft xp
GET SUPPORT AT HP.COM FOR INSTALLING A HARD DRIVE FOR YOUR COMPUTER MODEL.GO TO MAXTOR TO GET SUPPORT FOR INSTALLING THE HARDDRIVE MODEL YOU HAVE.JUMPER SETTINGS,ETC.
Aug 22, 2008 | Computers & Internet
Maxtor hard drive model 54098h8 where do I put jumper for main drive
on the model 54098h8 this is a IDE drive and was in service in the mid 2000 era. most drives warranty expired by 2003.
the jumper postion is for J50 which is MASTER with jumper ON and SLAVE OFF See photo below or look on this link
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/d540x-4k_guide.pdf
All material contained herein Copyright © 1999 Maxtor Corporation.Contents and specifications subject to change ®
without notice.DiamondMax™, MaxBlast™ Plus and MaxFax™ are trademarks of Maxtor
this is a photo of the master from the PDF
May 07, 2008 | Maxtor Hard Drive
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Maxtor 40gb hard drive
i think it's a conflict with the two hard drives maxtor (ata) and westen dig(eide) ,.....could be wrong....maxtor 40gb....west,260gb let me know
Sep 16, 2007 | Computers & Internet
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Computers & Internet Logo
3,666 people viewed this question
David Payne
David Payne
