Question about Asko W6021 Front Load Washer
Noise my washing machine 'squeaks' when on wash cycle especially when the drum is moving slowly - the noise disappears when the machine is in spin cycle. The noise 'seems' to come from the vack of the drum but not certain. i am prepared to take out the drum but cannot find the instructions on the net. thankyou in anticipation
  • sneeze Aug 13, 2008
    I have the same problem, It squeaks when spinning slow or in wash cycle.  Do I replace the "Vring cassette", Is it one whole piece with the bearings, will it harm my machine if I don't?  Other than the squeak it runs fine, just very annoying.
  • Anonymous Mar 22, 2014
    sound like object between inner and outer drums
  • 126 Answers
The squeking may be caused by the 'V'ring casette that enclosures the bearings. Have seen some episodes with that. It's very much work to remove the drum, so dont do it if it's not is absolutely nessesary!
Posted on Jan 23, 2008
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Making a lot of noise especially on spin cycle
Could be a bearing problem,turn the drum slowly and listen carefully you here where sound came from.Lift the drum upwards if there are a play it bearing alright.
Nov 28, 2014 | Washing Machines
Why does my washing machine make a load noise on the last 6 minutes of the spin cycle..especially when I have bed linens in.
It is not unusual for a machine to make a lot of noise and jump about when washing sheets as they can sit out of ballance in the drum. That is why the drum turns to and fro and short spins trying to balance the wash. If how ever the noise is rumbling like a big lorry going by, then I'm afraid it sounds like your drum bearings have gone. Replace bearings by an engineer or replace machine either is expensive.
Oct 01, 2014 | Samsung Washing Machines
My zanussi machine has started making a very loud noise since it was moved out to replace the flooring underneath (not a big deal) but this has worsened with violent shaking and creaking sounds during the...
Clothes with dark streaks or marks are often the result of a drum that is misaligned due to worn rollers and/or bearings. It's also possible that the drum is out of alignment due to the move (especially if it was tipped at a considerable angle). Try lifting and gently turning the drum to see if you can isolate a squeak or scraping noise that would point to the misalignment.
The marks happen when clothes get pinched between the moving drum and the stationary part adjacent to it.
Good luck from Detroit, MI.
Jul 18, 2011 | Zanussi WJS1397W Front Load Washer / Dryer
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Hello my Wirlpool washing machine makes a scratching noise when the drum is turning during the wash. The noise disappears however when the washing machine is spinning. Would it be worn out bearings?
You would hear the bearings in the spin cycle if it was them ....it would sound like you are at the airport...you will probably find that a bra wire has caught itself inbetween the drum and the tub and is scratching as it goes around.
Nov 11, 2010 | Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
Nov 05, 2017 | Candy Washing Machines
Noisey during wash cycle
sounds as if your brake pads have broken, try removing the lower acess panel you should see the broken pads lying somewhere under the machine(at least pieces of them), i bet if you spinn the machine the drum doesnt come to a complete sudden stop after lifting the top( it should if the brakes are engaging
Sep 26, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
Asko W6021 Front Load Washer Logo
621 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
