Question about Refrigerators
Fridge worked when i got it home after buying on ebay Then it stopped
  • Refrigerators Master
  • 2,694 Answers
How long 10 days to 2 weeks,if so oen freezer door,do you hear the fan blowing,if not you have abad evap fan motor,next touch the back wall,if there is snow or ice on back wall you have a defrost problem, what is it doing and what is the model number,without seeing it it's hard to help you,send more info
Posted on Nov 13, 2009
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
G.e. tfx25jrba leaking water on the floor.
Mine leaked because the plastic tubing which leads onto your cold water pipes was old and cracked. There is a shut off for the water mine is in the basement off the cold water line if you shut that off till you can go buy a new line at home depot or wherever it will stop leaking. DO NOT shut off your water supply just look for where they tapped into the cold waterline for your fridge. Look at the back of your fridge and you will see a clear tubing from your fridge probably leading to your basement you will see the same tubing coming probably thru the ceramic floor thru to the basement leading to a valve if you shut that off till you can replace the tube it will stop just don't take the copper tap off because it has been screwed in there and made a hole in the piping to feed into your fridge. The piece is about $10.00 at home depot or lowes, a plumber is about $150.00 It is easy to do. Tell them you need a new assembly for your fridge, If this is an ice maker fridge as I suppose it is. If not pull out the fridge and see if you see a clear tubing
Feb 23, 2011 | GE Refrigerators
I wanna buy some speakers wires for this system i cant find them anywhere7067676412 if you have them
Even if you can find them they'll probably cost a relative fortune.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Toshiba-SD-V55HT-Home-Theater-Systems-manual/id/284ag007/t/2/
Page 13 shows the wiring scheme.
The wire itself is just glorified lamp cord. Go down to Radio Shack or the hardware store and buy 100 feet of 18-gauge lamp cord and make your own - cheap.
Maybe bring the unit down to an electronic store and see if they have any compatible ends to match the proprietary outputs.
There are a couple whole non-working SD-V55's on eBay for under $60 delivered. If you check with the sellers to make sure the have the cables maybe you can work a deal.
http://cgi.ebay.com/4K33-TOSHIBA-SD-V55HT-HOME-THEATER-DVD-WORKS-FM-WORKS-/140508685542?pt=LH_DefaultDomain_0&hash=item20b6f864e6
http://cgi.ebay.com/Toshiba-SD-V55HT-Home-Theater-Receiver-DVD-VCR-PARTS-/160492805226?pt=Home_Theater_in_a_Box&hash=item255e1ddc6a
From what I've seen asked for proprietary cable sets, these would be bargains.
Feb 19, 2011 | Toshiba SD-V55HT System
My new Fridge is very close to the pantry which has a glass door, and I'm afraid the handle on the fridge door will break out the glass in the pantry door. Is there any sort of door stop I can place on...
I worked for sears home service working strictly on refrigerators and freezers till last year. To my knowledge there are no door stop that is offered by the manufacturer. That was one of the most common complaints for the french door model refrigerators. You may try to find something at your local hardware store.
Nov 12, 2010 | LG LRFC25750 Refrigerator French Door
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Unit stopped dead.no lights in both fridge and freezer. Does not run. checked power plugged into another circuit still nothing
The exact same thing happened to me. An LG service tech was sent to my home, only to tell me that he couldnt fix the problem.. a blown fuse. He said the entier fridge had to be replaced. You would think a blown fuse owuld be an easy fix, but evidentally not. LG did replace the appliance but after it was replaced they told me theyd only guarantee the new fridge for 90 days. After that, my extended service plan would come into effect. Good thing Id purchased that plan because my 90 days was up last month & now my ice maker has quit working. I will never buy another LG product!
Oct 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
My laptop's screen is not working properly. Sometimes it stops working for a second, it stays grey, like a bad TV conection. I don't know what to do. It's a HP pavilion dv5-1251nr. Usualy it happens for...
Try hooking it to LCD or external monitor if working then,buy a new LCD with removal instructions on Ebay.
www.ebay.com
If the external doesn't work buy a motherboard on ebay
Oct 03, 2009 | HP Pavilion dv5-1251nr Notebook
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
