Question about Vacuums
I can't remove nut from end of vacuum.
How do I remove the nut from the end of an oreck upright vacuum motor? What do I have to do to keep inside from spinning?
    Sniper:
  • 84 Answers
The nut is reverse threaded . If you hold the fan with one hand use a ratchet to loosen the nut, you will have good enough leverage to break it, but if you don't then here's a little trick....Take your vise grip pliers and clamp it to the belt end shft of the motor. Now with your worktable (or floor) brace the vise gripped motor shaft . with the ratchet, turn the nut to the right. Like you're tightening it. this should be sufficient enough torque to bust that nut. I hope I was able to help you , let me know. Thanks, Rene (the Vacuum Doctor)
Posted on Nov 13, 2009
Motor smells Oreck Xl2
If it smells electrical, than you may need a new motor. If it smells more like burnt rubber, than you may have a brush or motor problem. To check you brush, take out the 5 screws that hold your bottom plate on the vacuum and remove the plate. Disengage the belt and see if the bearings at each end of the brush turn freely. If they do not, replace your brush. Also spin the motor shaft by hand and see if it turns freely. Hope this helps!
Mar 02, 2015 | Oreck XL21 Bagged Upright Vacuum
Remove fan housing from oreck vacuum
First off take the bolt of the fan, that will allow the fan to come off of the motor alowing the fand cover to come off it takes some effort but it will come off. Best of luck, sincerely daxter.
Sep 02, 2014 | Oreck XL21 Bagged Upright Vacuum
How do I replace oreck xl21 fan?
That nut is a left handed thread, so you need to turn it like you would normally tighten it to actually loosen it. You will also need to hold the shaft at the other end with some pliers. I would suggest using a piece of cloth or leather over the shaft so that you do not scar the shaft when you grab it with the pliers. Hope this helps!
May 07, 2014 | Oreck XL21 Bagged Upright Vacuum
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck xl9300
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=767429
Oreck XL9300
Posted by Cubfan70 on July 10, 2008
Bought a new motor but can’t figure how to pull off the metal fan from the old motor. Is it muscle or a trick?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Oreck fan is generally held on by a nut on the end of the motor and is replaceable, and it usually slides on but over the years it tends to stick on the shaft so you can take like 2 screwdrivers – one on each side and try to lift gently and the fan should come off, if not try some WD-40, and look on the inside of the new fan to see if there are threads that might screw on, if not then it should just side on, make sure if you use WD-40 to wipe off any excess liquid. Check you owner’s guide in the back pocket of the Oreck XL9300 to see any instructions that they might have, or call the Oreck factory to get a new owner’s manual for the vacuum.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Reassemble of handle on upright
place handle half with the posts that hold the screws facing up.
silver pole with hole that goes completely throuigh goes over lower screw post (Long side)
static wire - L shaped end goes in small hole on opposite side of handle just below
vacuum switch hole, curve of wire should follow curve of handle and fits into top of
silver pole and pushes againt it providing push to hold siver pole.
hope this helps
Apr 02, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck belts keep coming off
If the pulley on the brush roll is worn, then I would replace the brushroll. Look at the ends where the brush roll sits in to make sure the casing hasn't over heated and not holding the brush in place. Also make sure the motor is shifting and causing the belt to come off. Another is if you are catching a rug or towel, that also will cause the belt to come off. I am assuming you using a new belt and not a worn one. After only a short time, belts stretch and need to be replaced.
Jan 22, 2008 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
107 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
