Question about GE Spacemaker 1.5 Cu. Ft. Over-the-Range Microwave - CleanSteel
GE spacemaker UMV1152AAW. Where can I find a glass cooking tray?
  • 100 Answers
The model number belongs to an Amana brand microwave.
Here's the link to the tray for that model...
www.microwaveglasstrays.com
Posted on Jan 21, 2010
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need a glass cooking tray under $30 for the GE spacemaker microwave. The model number is JVM1650BB005. Where can I find one?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 21, 2011 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
I have a 2001 GE Spacemaker #JVM1840CD001 that does not heat anything, but runs. What's wrong and how can I fix it?
If your microwave oven "works" meaning that your display, cooking tray rotates, and the light turns on when you open the door, but does not heat the food, the problem usually is with the magnetron circuit. If you hear a loud hum when you try to heat something in the oven usually means that the magnetron has failed. The replacement magetron is about the same price as a new oven, so you are better off buying a new oven.
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Noise
More than likely the rollers under the glass tray have build up on them. simply remove tray and rollers and clean rollers with soap and water.Before installing clean track area that rollers set in and should run smooth after that. If this doesn't do it then reply with more info about it < does tray move in a jerking motion?, does unit have circular cover in the top? in right upper corner there is perferated metal,is it discolored?> should be able to figure it out if it isn't rollers.
Apr 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Condensation marks on microwave door
For most microwaves the process is pretty straightforward. You can open the door and you will see the screws that hold the outerinside panel on to the glass. After you remove those screws you will see the screws that hold the ouside cover to the door in place. Once you get that far you will see what is holding the glass in place. Keep in mind to replace the gaskets around the glass right and anything you take off to get to the glass itself. If you are getting condensation from range top cooking then the seal around the glass may need to be replaced. You really cannot hurt anything by taking it apart, but it needs to be put back together exactly the way you take it apart. Good luck and hope this helped.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker - microwave works but the inside plate doesn't spin
you have a bad turntable motor or a bad control board.. start with the motor 9 time out of 10 this is your problem.. you can pick up this part at your local parts house or order online.. look for universal part. this will be alot cheaper then the oem.. just take the screws out of bottom panel under microwave. panel will drop down. you will see little round motor about 2in' make sure unit is unplugged.
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1.5 Cu. Ft. Over-the-Range Microwave - CleanSteel Logo
78 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
