Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
It is leaking water out the bottom when off and won't **** it back up through bottom chamber when on
  • 11,896 Answers
I personally would dismantle the covers as much as possible. Look for any leaky hoses or tubes. Look for cracks in the canister that could leak. Any air leaks can cause lack of vacuum pressure and release the liquid that is already there. Or if the pump is faulty or leaking, it won't work to **** or to hold pressure.
Posted on Nov 12, 2009
How do i get my bissell to stop leaking water?
The rubber gasket on the bottom of the 2-in-1 tank is probably lodged in the base of the unit. It should be connected to the nozzle on the bottom of the 2-in-1 tank. You can pull it out of the base and reattach it to the tank. This should stop it from leaking. The formula tank on the back has the same gasket so you can pull that out and see how it should fit on. Hope that helps.
Apr 05, 2012 | Bissell 2X Proheat 9200 rug cleaner
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do I fix my Rowenta Iron? It leaks from the base. It has never been dropped.
Some gasket of flat iron wear out in time. To remedy this problem you must first detect where the leak was coming from. Usually it comes from the area where the water meets the vaporizing chamber. When you found the leaking area you remove the water dry it thoroughly and apply a high temperature gasket maker at the leak and wait it to cure naturally. Usually one day is enough to get the flat iron to work again.
Jan 03, 2011 | Vacuums
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
How to empty
for this unit, you want to start by removing the hand vac portion.
along the side of the clear chamber towards the nozzle opening is 2 clips on either side of the unit.
Squeeze these clips together and the clear plastic chamber should come off. Pull the filter out of the chamber and dump out.
At this point too, you can choose to clean the dust cup, (soap and water) and the cloth filter in there (again soap and water). However if you do that, please make sure that the filter is 100% dry before putting it back into the unit.
Good luck,
Mark
Nov 10, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
How do i clean the two little top parts above the bottom empty dirt cup
hi there,
inside the dirt chamber you should be able to twist and remove both of the silver what look like arrowheads and you should be able to get up inside the top with a water hose to clean out the upper area there. Allow for the unit to dry before you put it back together.
Good luck.
Mark
Nov 09, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Water is leaking in the back and not going into
check bottom of reservoir thereshould be a rubber gasket make sure its in place or check to see if it fell out
Apr 08, 2010 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dyson Animal .. how to get to Chyclone chambers for cleaning??
The cyclone assembly is glued and cannot be taken apart. The best way of cleaning it , is to remove the top held on with three hex screws , the bottom collecting vessel and the perforated filter. Then blast the cyclones from above with either a pressure washer or hose with a high water pressure source. Leave to completely dry , then reassemble.
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Water leaking out from bottom of 7901
That part can go bad, but I have found more often the a water line came loose. Take out the 6 screw and the flow indictor cap, remove the top, then inspect that area. If you find what the problem is, fix it then when you put the top back on, make sure the piston is on the bottom of the smart mix valve and that the knob is in the water only spot, then push the top back on. If you need to replace the auto-load receiver, the part # is 2140710 and you can order from a local repair shop.
May 30, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
263 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
