Question about Motorola Mobility RAZR V3
Arrow buttons won't work - Motorola Mobility RAZR V3
How to turn off closed caption
For over the air usually on the lower section of the remote look for CC or subt.
If on cable the Close Caption is controlled by the cable box not the TV. Usually there is a CC near the cable select button on the cable box remote. If not found then go into the cable box settings and look for
  1. Press the SETTINGS button
  2. Use the arrow buttons to scroll to the LANGUAGE section.
  3. Scroll to Closed Captioning and press the right arrow.
  4. Press the right arrow again and highlight the Off option
For some setups it is more complex. This link may help you with.
My Closed Captioning Won Turn Off
Jan 05, 2016 | Samsung Televison & Video
Why does my xbox steering wheel just blink green and won;t connect
Your wheel needs to be synced. Press the sync button (it has 3 arrows on it) on the xbox360. Then press and hold the sync button on the wheel (lower right, next to the green light, also has 3 arrows on it), for about 3 seconds, then release. This should get you synced right up. :)
May 04, 2014 | Microsoft Wireless Racing Wheel for Xbox...
Bosch silenceplus 50dBA won't start
After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
Apr 12, 2012 | Dishwashers
When I push the arrow up to make my heater kick on a 1+2 pops up above the temperature number and it won't kick on.
sounds like your touchscreen is messing up and your adjusting the T-factor.. try pushing the reset button on your thurmastat.
Feb 26, 2012 | Heating & Cooling
I have a salt water pump 8110. It won't go pass start up and when I push the left button it just keeps beeping. It will not let me unlock the keys to set timer. I have already unplugged for 10mins....
Okay... Let's do this step by step...
1st... Press the down arrow button until you hear the beep and let it go quickly..
2nd ..Press the up arrow button until you hear the beep and let go quickly..
At this point, the LED reading should be blinking 00.. If it is, you have unlocked the keys and you can now press the up arrow button to increase the timer to 01, 02 and up to 12. Note: To adjust the time, press the up arrow button in short intervals, do not hold down the button. It tends not to adjust if you hold down the button longer than 1 sec.. I hope this helps and it not a bad unit.. If it did, please post a comment and rate.. really appreciated...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
Lately, my T-Mobile Samsung t239 phone's buttons on the slider part with the monitor attached to it won't work, like for example, the right side button that, when the home screen is on,...
i gues you have dropped it or it got wet. Bring it to your local telephone shop and ask to clean it. That only cost like 10 dollars and when they put it back together the align the keyboard
thats the best way to go
good luck
rene
May 28, 2011 | Samsung T239 Cell Phone
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
