Question about LG LMVM1945 Microwave Oven
I have the part I need, but I need to disassemble the door to install it. I don't see a way to do that...Model LMVM1945SB
  • 410 Answers
Remove the outer cover from the microwave oven to gain access to the door hinges. With the door off, and lying face down on the table, carefully pop-or-pry the plastic door seal off the inside. Presto, access.
Posted on Nov 12, 2009
Testimonial: "I hope it works...If it does, you're my hero!"
Model E130BM55HSC. How can I replace lower door handle bracket?
Hello Teresa, thank you for your inquiry!
I understand that you need assistance replacing a component on your Electrolux microwave. In order to replace the bracket you would need to disassemble the door. You should seek help from a professional technician for proper assistance with the disassembly. This will help you avoid any personal harm of improper disassembly of the microwave. Best of luck! -Matt
Mar 09, 2016 | Electrolux Microwave Ovens
How do you take off a microwave door and put a new one on?
KHMS155LSS0 - May 27, 2017
On many models you can open the door all the way and gently lift it off.
Otherwise, you have to do some disassembly.
The support page for your model, with manuals, is here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 27, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Need to replace cracked door of a Whirlpool microwave model mh1150xmq-o
See these files for disassembly info:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You may be able to get a whole door, or you may have to order separate parts for it.
If the latter, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Either way, you can find handy exploded views and order parts by model number here.
Jun 20, 2011 | Microwave Ovens
How do i fix a broken microwave handle on a kitchen aid? model# KHMS155LSS0
Your handle can be purchased from Sears at the link below, part number 7 depending on your color and finish A - C for $36.18. You can also view the schematic for the door and based on the picture, you can see how to disassemble the door by removing screw (Part Number 8).
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS0/0593/0123370/P0306212/00002?blt=06&prst=&shdMod=
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | KitchenAid Microwave Ovens
Touch pad doesn't work LMVM1945SB Microwave
that would be for a technician only........ electronic parts of that type are not generally self repair nor readily available
Sep 20, 2009 | LG LMVM1935 Convection/Microwave Oven
I got EMG4753 microwave oven...now 4 yrs old....it's door is not opening when press the door opening lever...pls advice
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety & disassembly info here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Sanyo UK support, parts and authorized servicers here.
Jan 18, 2009 | Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
Where is the fuse located
It would be helpful if you could reply back with your brand and model number, but I can give you a good answer without it.
First of all, this won;t be a problem with the fuse. When a microwave's fuse blows, the unit will be dead.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If yours is not listed, please reply back with your brand and full model number.
If you think the problem is on the control panel, which we repair these nationwide by mail for $39.95 postpaid.
Mar 25, 2008 | Microwave Ovens
Disassembly of GE JVM1460 microwave oven door to clean
Mar 10, 2008 | GE JVM1440 Microwave Oven
LG microwave oven
It's usually a bad door switch or a broken door switch mount. Once in a while it's due to a board problem. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 13, 2007 | LG LMVM1945 Microwave Oven
LG LMVM1945 Microwave Oven Logo
211 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
