Question about Pioneer VSX-517
How do i connect my projector to get sound from my
How do i connect my Optoma 16.9 dlp projector to get sound from my receiver!!! ok heres the set up my xbox 360 is connected to my projector with an hdmi chord the projector has about 5 outlets and one for sound which i connect a y rca stereo cable to the receiver and using another set of the same wires to connect the receiver to my speakers the speakers work fine from the receiver but when i turn the channel to get sound from my projector through my receiver to the speakers theres a problem!!! it doesnt work!!! if there is any one who can come over and help me fix this problem i will greatly appreciate it!!! or just give me precise info on what to do to fix this problem!!!
SOURCE: no sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Posted on Jan 03, 2009
  • 547 Answers
SOURCE: No HDMI Output thru' receiver
you most likley blew a fuse . take it to a repair shop it you live in an area that has lot's of storm activitey you might want to look in to getting serg protection on your elect panel to save repairing other thing's in your home. thank you please rate mee
Posted on Feb 12, 2009
  • 1114 Answers
SOURCE: Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Posted on Dec 05, 2009
Testimonial: "Got me on right path, but I'm still stuck."
  • 128 Answers
SOURCE: I bought the receiver on
The resistance or load on the amp is not an influencing factor here. Generally most receivers will handle 4+ ohms with no problem.
Did not understand the cable plug comment do you mean you do not have banana plugs? those are a convenience item more than anything the red & black terminals accept wire up to 10awg you just need to make sure no wire is sticking out and touching the chassis or another terminal.
You did not state what your source was so start with something simple such as a cd player or ipod that has regular RCA cable connections on it.
Culprits could be a variety of things here is a short list
1. make sure the input is set to analog not digital this is done through the menu.
2. make sure the speaker selector is set to speaker A and that your speakers are connected to the right terminals ie: not to the surround or front B.
3. if there is a tape loop make sure its turned off
4. in the menu make sure that the input source is set to the correct input... for example on many receivers have SELECTABLE sources so if you push video 3 the menu may allow you to select audio from input 2, 1 source etc... If the previous owner messed with the changes a full reset may be in order.
5. make sure the surround sound is turned OFF
If none of this works then its probable that the receiver was sold due to the issue . could be a simple blown fuse or could be a bad board. Ifs its not showing proitect mode then its probably a software issue/ blown fuse.
re-read the auction then contact your seller if all fails then file a complaint with Paypal
Posted on Sep 23, 2010
  • 961 Answers
SOURCE: xbox elite connected to TV
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Posted on Mar 31, 2011
Please help how can reset pasword on optoma ep721 model daeptng S/N Q88N744AAAAC2822
The default password is 1234
Disable password in Menu >> setup >> security
set Security << OFF >>
Here is a link to the manual as well
Aug 27, 2014 | Optoma EP727 XGA 2200 lumens DLP...
Optoma hd65- componant signal OK but no hdmi signal found
whats the reason for no display on hdmi to hdmi connection- to the x box display is fine-?
Jun 25, 2012 | Optoma HD65 DLP Projector
I have a Optoma projector HD70 How do you reset the lamp operating time?
Do the following for reset the lamp hour.
1. Press the menu button
2. Select Options.
3. Select lamp settings
4. Select lamp reset.
5 Select Yes
Jul 08, 2011 | Optoma HD70 DLP Projector
Lamp comes on briefly and then goes out
Check poewer connection
Check if fan filder is dirty ( if it is just hoover it out)
If "lamp" light on top of the projector blinks or stays lit - lamp probably faulty
How old is the Projector/lamp (average lamp life is around 2000-3000 hours)
Mar 01, 2011 | Optoma EP719 DLP Projector
How to connect the Optoma Pico PK-101 DLP to a laptop
You have to buy a 17€ converter.... here on my website, is a diagramm on the B chapter that explain a lot.
Here is the link to buy one converter
Jan 05, 2010 | Optoma Pico PK-101 DLP Projector
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Pioneer VSX-517 Logo
179 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
