Question about Sharp AR-5320 Black and White Copier
My sharp copier tears papers and creates a black line on the pages.
  • 11,896 Answers
I believe you may have a slight paper jam. There may be a slight junk of paper or it is not inserted perfectly straight.
Posted on Nov 12, 2009
Why is there a Black line on paper when using feeder on sharp copier?
The black line is a build up of dirt or ink on the glass where ur copier "sees" or reads the image that is being copied. Cleaning of the unit is reccommended and should fix ur issue
Aug 01, 2014 | Sharp MX-M232D Multifunction Copier
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
1 black line at the end of paper
if u take copy from adf scanner then clean the scanner glass. if the line is coming on print & copy both then check drum is there any line
Dec 19, 2012 | Sharp AR-5316 Advanced Digital Imager...
My Sharp copier make a black line right in the middle of the paper.Haw can i fix it?
check first where the source of that black line, print it one page, remove the fuser and copier/developer and trace if mark line is noticeable.
Apr 16, 2010 | Sharp AR-5316 Advanced Digital Imager...
My copier keeps tearing papers.
Paper tears due to the following;
a. Improper paper size on tray
b. Putting excess papers on tray
c. Dirty feed rollers
d. improper jam removal
Rectify the above.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Auto Tear off for Epson LX300+
friends
you have to get the exact page size of your continuous paper. then you go to start -> printer and faxis -> then go to file -> and server properties.then create one paper which is exact sixe of your paper. Then go to printer preferances and select that paper.
to switch on tear off refer manual.
Hope this can solve the problem.
Feb 27, 2008 | Epson LX-300 Matrix Printer
Sharp AR-5320 Black and White Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
