Question about Refrigerators
Where's the thermostat?  I have a honeywell oil-fired water heater in a Bock tank.  I need to turn the thermostat down to 120 but can't find it anywhere on the tank.  The water is currently 130 coming out of the tap.
  • 308 Answers
You should see a grey box mounted on the hot watertank, it may say honeywell, or white rodgers, or some other name, but if you remove the cover to the box you will see a dial, adjust accordingly
Hope this helps
Posted on Nov 12, 2009
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
My water heater is not turning on at all.....it is three years old
There are many things that could be wrong with an oil fired hot water heater...oil burners are not something that a novice should mess with as they can be very dangerous...
Please hire a por to figure thsi out for you..
heatman101
Jan 30, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
My 32E Bock Oil Water Heater will not fire up. What is the gap between the little lighter fingers? Or whatever you call them? We got it to fire once but then it went out again shortly. We have checked...
Hello You have a clogged oil filter or oil line.The (electrode) gap should be left ALONE.The line needs to be blowin out & replace the filter element then the flameout will stop.
Sep 03, 2010 | RTO Bock Water Heaters 32E 32 gal 104,000...
Have hot water but no radiators. Checked pilot
sounds like your circulating pump is bad or electronic zone valves
Oct 26, 2009 | Honeywell Programmable Thermostat Heater
Water heater not firing up
Make sure thermostat is turned to 120 to 150 degrees Fahrenheit. Turn the thermostat down and back up to see if it ignites. If it lights put the cover back on and set it to temp you want it to be. if not, you have a bad thermostat.
Hope this helps.
Aug 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Control Rheem water heater temperature based on schedule
This is probably not what you really want to do. It will use more energy to reheat the tank than maintain a full tank of water.
Jun 25, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
May 08, 2009 | Honeywell Programmable Thermostat Heater
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
