Question about Samsung CLX2160 Multifunction Color Laser all-in-one Printer
I have a clx 2160 printer and it has come up with message "replace transfer belt" can anyone advise what this is and best place to get one and can i do it myself
    President:
  • 2,306 Answers
Check at www.precisionroller.com they have many of these parts for Samsung. Once you get the new one you replace it by first removing the toners and drum, the transfer belt is next to remove from the front.
Posted on Nov 12, 2009
Transfer belt
the est solution is to take it to an it repare place
Jun 17, 2013 | Samsung CLX-6210FX Laser Printer
Samsung clx-2160 printer is showing transfer belt error. how do i sort this
transfer belt (and other consumables) will reset follow this procedure:
1. go in diagnose mode:
menu - # - 1934 - menu
2. in tech mode -consumables counter - transfer belt -reset
3. after 20 sec. power off and power on
When transfer belt count 60.000 image need to reset.
good lock!
May 28, 2011 | Samsung CLX-2160N All-In-One Printer
Hi, I have had my CLX-2160 printer for 3 years now and its started to print with a fade on the left side only and have just under half black ink left. Is it worth changing the black toner cartridge or does...
Hello.
There are two reasons the fade happens. Running out of toner and the drum not responding correctly. The Drum is the unit that transfers the toner to the paper. if it gets damaged or dirty inconsistent print is usually the result. Try taking the toner out, shaking it and replacing it to see if it affects the print quality. if it does not price a replacement drum and toner, compare it to the price of a new printer and this will answer the second part of your question!!!
I hope this helps Regards GM
May 27, 2011 | Samsung CLX-2160N All-In-One Printer
Belt Error, clx 2160
Your printer has a "IMAGE TRANSFER BELT". This belt has a marker on his surface. This error means that the image belt does not move, or is damaged. Probably you will have to replace the belt with new one( This part is made for 20000pages).
pifonski
Feb 19, 2011 | Samsung CLX-2160N All-In-One Printer
I have a Samsung CLX-2160 print. It says "transfer
Try this steps it might help,
1. detach the paper tray and push it back correctly.
2. open the front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and in the left side of toner unit there is a sensor door, behind that door there is also a light sensor bulb, which needs to be cleaned by a cotton bud.
Please rate this solution if found useful.
Thanks
Jan 17, 2011 | Samsung CLX-2160N All-In-One Printer
How to fix transfer belt error for samsung printer CLX-2160
Did you try turning the machine off, unplugging it, then plugging it back in and turning it on? Usually this procedure will cause the error message to go away.
If the error does not clear, you'll need to call a service technician.
Sep 16, 2010 | Samsung CLX-2160N All-In-One Printer
Transfer belt error samsung CLX-2160 help
The first thing to try is to turn the printer off, unplug it from the wall, then plug it back in and turn it on. If the error message goes away, you can resume normal operation. If the error message still appears, you'll have to call your service technician.
Feb 09, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-2160 says waste tank is full. What must I do and where is the waste tank?
If you open the front of the printer then you will find a waste tank in the left side - its gray. Take it out and empty it, and put the tank back in place.
This works for Samsung CLX-2160
Jan 31, 2010 | Samsung CLX-2160N All-In-One Printer
Replacement transfer belt on my Samsung CLX-2160 not recognised?
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Dec 12, 2009 | Samsung CLX2160 Multifunction Color Laser...
Samsung CLX2160 Multifunction Color Laser all-in-one Printer Logo
290 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
