Chuck does not function properly on drill - are they interchangeable?
  • 89 Answers
Yes you can purchase replacement chucks try your local hardware store , or look up tool repair in the yellow pages
Posted on Nov 12, 2009
  • 11,896 Answers
Yes you can interchange most of them. As long as internal shaft is same size you are good.
I lost my chuck key. what one will I need to buy
39 No Drill Chuck Key? No Problem • How To Remove Drill ...
? 5:23
https://www.youtube.com/watch?v=AtB1MTYtgt8
Nov 19, 2010 - Uploaded by AskWoodMan
All you need is a slip joint pliers and the proper size drill bit. When a drill chuck key goes missing, it can ...
DIY - Missing Drill Chuck Key? - I Have a Solution! - YouTube
? 1:10
https://www.youtube.com/watch?v=MIegFURsGFE
Jan 16, 2016 | Drills
The chuck on my Craftsman C3 drill won't stay tight
If you have a keyed chuck then yes as the jaws are not parallel any more from wear. If keyless then the thread inside the chuck cover is damaged and not tightening properly. So again yes a new chuck will be the answer.
Jul 29, 2013 | Craftsman Drills
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
The adjustable chuck on my sons Jet JHM-610 comes off when using it in the milling function. What is the best fix for my situation? It is coming off at the taper.
You should really be using end mill tool holders for milling. The torque is too great for drill chucks. You will get better results machining with surface finish, size as well as longer tool life. Side note..take care with reassembly of drill chuck. Tapers must be dirt and burr free or chuck will have run out as well as taper lock will break and come apart on you more often. If there is damage to the tapers replace the arbor and or chuck with new.
Apr 29, 2011 | Jet JHM610 Hobby Mill Drill
Will the te6a chuck fit ate7a drill
I looked at a breakdown for both tools and neither one lists a chuck, I know they have one and I would think that they will interchange BUT I would suggest calling them at 1-800-879-8000 and speak with a technical specialist for the final answer. Hope this helps
Apr 27, 2011 | Electric Drills
'Whats the difference between a te c3x bit and a sds bit'
The difference is the type of shaft on the bit so that it matches to the chuck type of the drill...They are NOT interchangeable!!!!
You need to know which type of check your drill has and order accorndingly...
heatman101
Aug 25, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
The chuck froze. The drill was used one time and stored in the shop. Unusually damp air caused the chuck to freeze up. I broke it trying to free it up. I need to buy a new chuck. Where can I buy parts.
chucks are interchangeable through the center of the chuck is a screw usually reverse threaded remove it and bring it to your local hardware store they should be able to get you one,if they don't carry it already. i have purchased some through True Value hardware stores.
Jan 22, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
I have a DeWalt D25114K XE. When the drill is on
try tightening the screw down the centre of the chuck with the jaws fully open
Nov 16, 2009 | Drills
I have a very old 3/8'' elecric drill, I think it ia a Skil, The key chuck does not work properly and I want to replace it. How do I remove the old chuck?
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 12, 2009 | Drills
41 people viewed this question
k24674
jasbo
jasbo
