Question about Mitsubishi WD-65732 65" Projection HDTV
Sometimes I get a Black square on the screen (like a menu but black) by hitting the exit button it goes away until an adjustment is made Volume / Channel. I noticed it first on DVD's about 50% in the same DVD player. The cable / video was ok never a problem, but now I'm using the RF / antenna input is doing it. Has this happen to others, is it re-occuring?
  • 647 Answers
Check your Closed Caption(CC) settings with your on screen menu if CC is on turn off
Posted on Nov 12, 2009
How do i get rid of a black rectangular box at the top right hand corner of my monitor?
if it does not go away on its own, try pressing the menu button one more time, or scrolling down to exit. if you're in a submenu, hit back until you're at the main menu then wait. if it doesn't go away, scroll and select exit. if it's a plain black box, try removing the power cable from the back for 10 seconds, and plugging it back in again.
Feb 03, 2015 | ASUS Computers & Internet
JVC AV-27D202 27" TV has a black box covering most of the bottom half of the screen. It goes away when you adjust the volume or do something in the menu but then it comes back again when the volume display...
It sounds that the Closed Caption function [CC}, is not set to ON. Set it OFF. Push the button marked {CC} at the remote control once to get rid of it. If there is no CC button on the remote control, you have to enter its service mode option to deselect it. If you wish to get more details about how to enter, adjust and exit the service mode, check the site linked here. If you're not qualified, do not go further, and contact any technician for help. http://electronicshelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 26, 2013 | JVC AV-27D202 27" TV
The picture on my Compaq monitor shifted 1 inch to the left. There is a one inch black space on the right side. I have a HP Compaq d530 CMT
click menu button on monitor. you will see a series of Icons (or scroll through a series of Icons) and one will be a square with a smaller square inside it that is half inside the larger and half out. Navigate to that Icon. Use the + or - buttons to move the screen in either direction until it evens out. Use + or - button to navigate back to exit and and then press menu button to exit screen. Or, sometimes you simply push the menu button a second time. These 3 buttons will be on the bottom front of the monitor. Good luck
Oct 21, 2010 | HP Compaq d530 CMT Intel Desktop PC -...
A Black square keeps appearing on screen, and wont leave
Hi big john
To answer your question;
What you have is closed caption(CC) in text mode.
To remove it ;
On the original remote there is a button labeled CC
Hit that button until you see closed caption OFF
Hope this help Cheers
Apr 27, 2010 | JVC AV-32D305 32" TV
Television hAs a black box blocking picture in the middle o he screen. when you hit volume the black goes away until the volume icon goes off
Go to ur tv menu.Go in captioning turn off all 1,2,3 and all txt will stop the black box in the middle of the screen.
Mar 26, 2010 | Toshiba 32A33 32" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Black square
hi! goto menu then, turn off the caption >avtrac
May 25, 2009 | Televison & Video
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
LARGE BLACK RECTANGLE BAR BLOCKING TV SHOWS -- WILL NOT GO AWAY
It sounds like the closed captioning background.
Press Menu on the remote
Press Up or Down, Ch + or C- to get to Closed Caption
Press right side button or Vol+ and Mode will be highlighted
Press right button or Vol+ until it says Off on the right hand side of the Menu
Press exit and that should do it.
Hope this helps.
Oct 17, 2008 | JVC AV-27D303 27" TV
Mitsubishi WD-65732 65" Projection HDTV Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
