Question about Garden
Does the john deere 14sb have a jet in the carb
  • 486 Answers
Should be a Kawasaki engine with a Mikuni carb, and there will be a removable jet in the center post of the carb.
Posted on Nov 12, 2009
John deere 455 keeps dieing
Clogged pilot jet inside the carb. You need to remove the jets and ream them so they are clear. If it starts and then dies as soon as you try to throttle up, then it is the pilot jet.
Apr 25, 2017 | John Deere Garden
How do you replace the clutch on John Deere 14sb walk-behind?
google your question. all sorts of help popps up
Jul 15, 2014 | Garden
JD 14SB won't stay running unless you spry gas into carb
could be number of things....low compression....valve clearance...blocked jets in carby...air leaks...
Aug 02, 2010 | John Deere Garden
My John Deere 14sb walk behind mower will start, and then within three seconds, it will die.
Sounds like after the prime fuel is burnt up, it dies. This sounds like either a jet is clogged up or a diaphragm, depending on your carburetor, needs some attention. Look at what engine you have on the mower. You may be able to clean the jet, depending on your mechanical abilities, yourself.
Oct 03, 2009 | Garden
John Deere 14SB (with Kawasaki FC150V motor). It
sounds like the valve clearences need adjusting they should be set at 0.004 thou you should be able to find an exploded view at pats small engines site.
Aug 09, 2009 | Garden
Won't run and try use starting fluid that engine
did u make sure your jets r set in the carb or are your vacum lines hooked up right.
Jul 06, 2009 | Garden
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Garden
Garden Logo
573 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
