Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher will not drain
Dishwasher will run through cycle but will not drain
  • 4 more comments
  • Anonymous Mar 04, 2008
    no water is draining out of the drain pipe
  • Anonymous May 12, 2008
    My Bosh will not drain after final cycle, leaves dirty water in mach after cycle is done
  • Anonymous Sep 02, 2008
    same as the above
  • Anonymous Oct 16, 2008
    my bosch just started doing this...after the countertop screws fell out and the whole appliance tipped forward...nothing is holding it in and the screws appear to be too short to hold it onto the formica counter..longer ones would go thru the counter...was thinking i needed to call someone to reinstall..but good to know others have this problem...let me know what works
  • kirkbro Nov 13, 2008
    Same problem
  • fruitdebris Nov 20, 2008
    My 4-month old Bosch "Ascenta" SHE4AM12UC wouldn't go thru a whole cycle, stopping w/dirty dishes and dirty water that would not drain. Filters are clean. Got plumber to look at floor drain (OK). We started and canceled "quick wash" 3 times. Each time he saw water coming out, but only on the 3rd try did dishwasher drain completely. What's up? Anyone know?
    - Plumber did straighten dishwasher drain tube to avoid kinks during our 3 tests. Lowe's installer claimed a floor drain would be OK. Their service dept. said problem must be our plumbing (and our expense!). I had plumber move drain tube to go thru disposal instead. So far (1 day), dishwasher is working and draining fine.
  • 25 Answers
IMost often something has just jamed the drain impeller, take out the filter plate in the bottom, then in the sump to the right side is the cover to the drain impeller. It has one screw in it a
T-20 torx take that out then lift up on the cover. After that use your finger to turn the impeller if it is jammed you will need to find what is blocking it then reassmble
Posted on Feb 16, 2008
Make sure plug in garbage disposal is knocked out, and make sure line has no kinks also line is at correct height
Posted on Jan 08, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 11 Answers
SOURCE: Stopping the Cancel/Drain Cycle
Disconnect the Drain Hose from the plumbing under the sink and using a bucket hold the hose in the bucket and attempt to drain the dishwasher. If you have a disposal and recently replaced it, the knockout plug may be still inside where the drain hose attaches into the disposal. To determine if it is still there, using a screwdriver, stick the screwdriver into the drain hose hole on the side of the disposer and if you feel blockage then the knockout plug is still in the disposer and will need to come out. To remove the plug use a short screwdriver and a hammer and place the screwdriver into the drain and strike the top of the screwdriver once and the plug should pop out of the disposal. Be careful not to hit the disposal too hard or to damage any plumbing. Reattach the drain hose and you should be all set. When you remove the drain hose if the machine is flashing an error code, go to the circuit breaker box and turn off the breaker for the dishwasher, wait 5 mins and turn it back on. This should reset the board and the machine should operate properly.
Posted on Feb 05, 2009
Samsung new dishwasher will not run through a cycle or drain properly. Water left in bottom. Keeps stopping and going to quick flashing.
The drain hose from the dishwasher may be partially or fully clogged with food stuffs like peas, corn, green beans, or other foods. disconnect the drain hose and clear debris from drain hose and run threw drain cycle.
Mar 16, 2013 | Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwasher runs though cycles but fails to drain in the final cycle
Hi...
If you dishwasher fails to drain you need to check this following:
  • Check sink drain and drain hose for restrictions
The drain hose and recirculation hoses can be responsible for leaks. The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
The timer motor regulates the length of time power is routed to each component. If the timer motor does not function properly, it can result in a wide range of problems. Common symptoms include sticking in a cycle, cycle times running too long, or failure of the dishwasher to start at all.
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | Dishwashers
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Meile G638 I Plus dishwasher
Problem solved, the dishwasher starts its wash cycle with a drain sequence, the pan did not drain in time for the wash cycle to continue , thererfor locking it out on inlet/drain alarm. I removed the drain hose from the S trap, then the non-return valve from the filter basket, made sure the drain pump impelar was free, blew down the drain hose back into dishwasher to clear any waste in the pipe,then found a block in the S trap orifis, after clearing that, reasembled and test run on cold pre wash cycle this runs for aprox 10 min.customer was very happy.
Mar 30, 2008 | Dishwashers
Rinse cycle
is the drain from the dishwasher in a syphon or runs into a free drain that air can break siphon cycle
or is drain up high enough eg 600 off floor be fore going into drain if not water will run in then straight out
Feb 23, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
288 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
