Question about Dell E196FP 19" LCD Monitor
Monitor is blank and the power light keeps flashing green.
    Master:
  • Dell Master
  • 956 Answers
When you switch on both Poota and Monitor, is there visual startup flashes or startup information showing on screen.
Make sure the monitor connect to rear of poota is located and firmly in place and properly screwed in?
Posted on Nov 12, 2009
  • 3 Answers
SOURCE: Green light and screen flash then go blank every 3-5 seconds and nothing else
Not sure I can tell you the exact nature of the problem with the info you have given. However, here are some trouble shooting tips. These are the things I would do to figure out what is causing the problem: 1. Hook up a monitor that works so that you can make some configuration changes to the graphics card. 2. Find out the native resolution of the LCD monitor that has the problem. Many 17 inch and 19 inch LCD's are 1280 X 1024 with a refresh rate of 60 Hertz. It is quite possible that your previous monitor settings are not compatable with your new LCD monitor. This is an easy fix. So go into your graphics control pannel and start by making sure that your refresh rate is set to 60 and the resolution to 1280 x 1024 or perhaps even lower like 800 x 600 but 1280 x 1024 is fairly standard with many LCD's. 3. With these new settings hook your LCD monitor up again and see if that works. 4. Still not working? ... Then there may be a problem with one of the hardware components in the monitor. When the monitor flashes are you for an instance seeing an actual picture? If so then the problem may be with your lamp controler. It's what controls the brightness etc. of your monitor. What you can try to do is lower the brightness. This sometimes restores the monitor to being useful. ie. you can use the monitor but only at a lower brightness. Setting the monitor to a lower brightenss may be a bit of problem if you can't see the brightness control which is often displayed on the screen itself through the menu function. If you are briefly seeing a picture as it goes through this 3-5 second cycle then hit the hardware menu button on your monitor. You should then see some sort of menu that you can control with the other buttons on your monitor. Find the brightness selection and lower it. You can lower it all the way to 0 and still have plenty of brightness to see a picture. NOte: you may have to make the change in brightness within one cycle of it going off and and on because each time it cycles it's quite possilbe that it resets itself. So in this case you would have to be really quick with the menu buttons on the monitor. It might take a couple of tries (or more) to get the squences of buttons you need to hit to get the brightness down. I had this problem once with a monitor and I was able to get the brightness down but only after many tries. I had to be supper fast with my menu selections. After that was done it worked flawlessly again. 5. Still not working? ... you are right you probably should have bought a new one LOL ... or next time when buying a used one make sure that you see it functioning correctly on a computer before buying it etc... Best of luck. Sincerely, Dean Dean Kenneth Robinson techinfo@ContinuousMix.com
Posted on Aug 16, 2006
SOURCE: blinking monitor power button and flashing image
i bought a new acer 19" . i will try to change the capacitors and see how it works. if not, i will try the power inverter option. but my new lcd itself cost me 100$ after rebate. so paying 70 pounds for an inverter is unwise. previous poster, I am sure it is problem with monitor and not the connector coz it doesn't do the self diagnosis. thanks for all the responses so far.
Posted on Jun 12, 2007
  • 85 Answers
SOURCE: HP mx705 17 in.CRT --Blank monitor
I assume the monitor is still plugged into the back of the system?
If so, do you get any beeps which can denote error codes for the system?  Put your ear to the monitor, any strange whinning noise?
Posted on Oct 23, 2007
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 109 Answers
SOURCE: vs17e monitor is blank,but power light keeps
you need to change ligth inverter check at
www.lcdparts.com they give you instruccion
how to do it
Posted on Aug 18, 2009
My monitor is blank. The power light is blinking ...
Throw it Away and buy a new one (its cheaper)....
May 14, 2010 | Computers & Internet
Hi I am running Triple Acer AL1912 LCD monitors on a Mo-View triple monitor stand. I have run these for a couple years without fail. PC is running 2 video cards a NVIDIA GeForce FX 5600 and a NIVIDIA...
Most comon problem with monitors are bad caps in the power supply, any good reapair shop should be able to fix them easily, see pictures of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
At least you will have some info so you will not get ripped off by repair shops.
Mar 01, 2010 | Acer AL1912 19" LCD Monitor
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Xerox computer monitor light keeps flashing
try swapping a known good monitor to make sure its the monitor?
http://www.aa1consulting.com
Jul 26, 2009 | Xerox XG-71D 17" Flat Panel LCD Monitor
Flashing green light
http://www.xerox-displays.com/drivers.html
This is the link to the xerox install info. This should fix the problem. If it does not please list the CPU OS and video card you have. Before connecting the LCD monitor make sure in your display properties are set to a refresh rate of 60 hertz. You can set refresh rate by going to the control panel in windows and display settings properties.
Jan 16, 2009 | Xerox XG-91D 19" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Pop goes the weasel
I agree. The monitor probably blew a capacitor.
Time for a nice new LCD monitor.
Dec 14, 2007 | Computers & Internet
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Dell E196FP 19" LCD Monitor Logo
151 people viewed this question
Alun Cox
