Keep getting bad ping times on my Cisco Linksys WRT54G2 wireless router. I get awesome ping times when my PC is connected straight to the modem. What can I do to get better ping times with the router?
SkinWill
  • 148 Answers
SOURCE: Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Posted on May 01, 2008
Bat1956
  • 585 Answers
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
MNfisherman
  • 11896 Answers
SOURCE: How do you change network key/PW for the Cisco
go to internet address bar and type in 192.168.1.1
It will bring you to router's software.
If it asks for username and password type admin for both.
Posted on Oct 02, 2009
  • 4 Answers
SOURCE: I have a cisco linksys wrt54g2 v1 that I have
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Posted on Oct 24, 2009
Testimonial: "Thanks a bunch!! I was about to pull my hair out! You are the Man!!"
SOURCE: can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Posted on Dec 19, 2009
Slow internet speed when connected to router
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Jan 26, 2013 | Linksys WRT54G2 Wireless Router
I have a modem cable connection with time Warner cable but router isn't connecting to modem what can I do
I install Linksys routers all the time. Usually the first thing I do, is update the routers firmware. Many times I find that if the Linksys router doesn't automatically get a connection from DHCP, updating the firmware usually solves it.
To update the firmware:
Connect just to the cable box so you have an active internet connection.
1. Go to: http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2/download
2. Select your router version (can be found on the sticker near the model number) and download the latest firmware to a spot you will remember.
3. Now connect the router to your cable modem and computer.
4. Access your routers configuration page (If you don't know the address try: http://192.168.1.1 or http://192.168.0.1).
5. Log-in - if you haven't changed the username/password the default should be a blank username with the password "admin".
6. Click "Administration"
7. Click "Firmware Upgrade"
8. Click "Browse" and choose the firmware file you downloaded in step 2.
10. Click Upgrade. Be patient and let it do its thing.
See if you connect after that. If not, let me know and I will walk you through the next steps.
Regards,
KYTechnology
Mar 04, 2011 | Linksys WRT54G2 Wireless Router
I have a LinkSys WRT54G2, Vers 1.0 router with the latest firmware installed and basically default configuration. I usually have 3-4 PCs connected to the router. I frequently loose connection to the...
Sometimes, you might face a situation where your wireless icon shows that you are connected to the Internet but you just can't access any websites. What do you do when you face this problem?
This article will show you how you can repair Internet connection when wireless icon shows connected, but unable to go online.
To connect to your wireless network with Wireless Zero Configuration, please click here.
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is "192.168.1.1."
Dec 06, 2010 | Linksys WRT54G2 Wireless Router
I have a Linksys by CISCO Wirless-G WRT54G2 Router connected to a High Speed Ethernet Modem and to my Desktop Computer. It gets fairly good signal sent to my laptop across my house. I also have a Belkin...
If your computer has 3 bars of signal, it's ok, don't mess with it.
If you want better reception, you can connect the Belkin wireless router near your notebook with a cable to the Linksys router.
Nov 04, 2009 | Computers & Internet
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
Can't install linksys wrt54g2 router with arris tm602g modem
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
Installing Linsys (CISCO) Wireless G router
It's not that easy to solve your problem plainly through text. I will try to do my level best. As you told that your LAN card is ok with other connections then its ok. Now every modem which connects to a router to for providing broadband connection has router IP. I'd suggest you to uninstall whatever softwares they have provided to you and restart your pc. Start your modem and make sure that you are getting continuity from the line to your modem. open your browser and type the router ip in address bar and press enter. if its asking for a user name and address contact your isp and get them. Comment back if you have reached upto this stage.
Jul 25, 2009 | Linksys WRT54G2 Wireless Router
Cannot connect both XP computer and Vista to Internet
A lot of cable modems will store the MAC address of the first device connected to them and will only talk to this particular device/MAC address. If this is the case, you will need to power down the modem and the router for some period of time. If you also get phone service through your cable company then there may even be an internal battery backup that you have to exhaust. Unplug it and wait at least one minute after all lights are off and then turn it on first followed by the router. The router should then register its MAC address with the modem and then all will be good.
If your modem or some other equipment owned by the cable company permanently stores the MAC address then you will need to one of two things. The easiest is to call the cable company's tech support and ask them to change the MAC address for your account to match your router. The seoond option is to configure the router to clone the MAC address of your XP box. Here is a link to a thread on linksys' web site with step by step directions:
http://forums.linksys.com/linksys/board/message?board.id=Wireless_Routers&message.id=108261
Note: If you want to implement security, do not use WEP as indicated in these directions, use WPA. WEP is hardly better than no security.
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
Setup linksys wrt54g2 broadband router with prolink h9200 modem
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
