Question about Kenmore 73952 Gas Dryer
Kenmore Dryer will not start
My wife fininshed a load and the next one she put in dryer, the dryer did not start. You have to continue to push button to make it spin. The vents are clean. Model # 110 70972990 - gas dryer. Also, where in the dryer is the part that is in need of repair. Sorry, I'm just a beginner in trying to fix my home dryer. I'll try it first before calling the repair man.
Lui
  • 1 more comment
  • Cass74 Jan 10, 2008
    I have a similiar problom with my Kenmore electric dryer. Except it won"t turn on at all. The timer makes the ticking noise as always but the start button does not work. I have checked to make sure no wires came loose or burned out. So far it looks like everything is intact. I would appreciate some help in fixing this.
  • lowriderbass Jul 07, 2008
    My friends dryer just ticks but does not turn on? All power is there and it looks new. Any ideas how to fix it?
    Thanks James
  • sau427 Dec 19, 2008
    my kenmore gas dryer woun't start . can anyone help.
    thanks
My kenmore dryer 80 series wont start the start switch just buzzes and the drum does not turn i put a new switch today vacuum it and check all belts they seem fine dont know what else to do
Posted on Dec 12, 2010
    New Friend:
If you have to hold the start in to spin the drum, try to replace the "switch Push to Start" about $14.** i have a gas dryer #70972.
Posted on Dec 05, 2012
I have a 70902990 that will not start. The button when held clicks, but nothing happens. we let a day go by and it worked for a while, but now is back to the same problem.
JM
Posted on Jan 11, 2008
For anyone else with this problem, I have two replacement boards. One came with my dryer and has been used, the other is brand new. I bought the brand new board to fix the dryer myself and as it turns out, that wasn't the problem. Replacement boards are usually close to $100 a piece ... I will sell for much less.
Posted on Sep 24, 2008
Hi Guys,
my kenmore dryer wont give any heat
i changed something a broken part. but still the same
anyone can help?
Thanks
Posted on Jan 31, 2008
    President:
  • 878 Answers
Lui, sounds like your even heat board failed. The dryer will run as long as you hold the button down. The board is under the consol on the left side. Easy to change out. Go to repairclinic.com and enter your part number, 3976609 and it will bring up a picture and price. Save your self the labor. Catriver.
Posted on Jan 10, 2008
Our Kenmore Front loader Dryer Mod # 110.61402310 i put our clothes in the Dryer and powered it on and then Nothing wont Power on
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. hope it helps
Feb 13, 2015 | Kenmore Dryers
My Kenmore Series 70 Dryer will not start at all. No sensation of the start button doing anything when I push it. Thermal fuse continuity is good (0 ohms). Light goes off inside the dryer when I depress...
most likely its the push button that is bad. you can buy one from any appliance dealer that services a kenmore dryer. the part is a reasonable price. you also have to give them the model number and serial number. have a good day!!
Oct 15, 2010 | Kenmore Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
It's a gas dryer, just dried a load fine put in the next set the heat dial shut door and pushed the start button, nothing happened.
heatman101
Aug 24, 2010 | Kenmore Dryers
Have a kenmore dryer model 110.66912692. Wife was using it for multiple loads today and then it stopped working. You can hear the timer ticking, and the push to start button makes a click noise like it...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Kenmore 73952 Gas Dryer Logo
4,348 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
