Question about Sharp AL 1631 Copier
The laser light does not come on to scan the copy.
  • Sharp Master
  • 1,297 Answers
Verify the exposure lamp comtinuity.
Posted on Nov 14, 2009
How do I fix Kyocera fs-1118mfp which outputs only partial copy of any document. When making a copy only part is copied. Placed the original on glass.
check to see if all the lights are turning on as it tries to scan (do a scan with the lid up and nothing on the glass.
Possiby need to rplace the drum in the printer.
Sep 01, 2016 | Kyocera FS-1118MFP Laser Printer
Sharp MX-M453u. Why does it yield light copy?
HI,
Did you set up the new developer?
Cheers
Andy
May 18, 2015 | Sharp Mx-M453u mx-M453u
Copy and scan problem
you check printer propete and ink resolution is best quality and the solve your problem
Apr 18, 2012 | Panasonic KX-FLB801 All-In-One Laser...
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Xerox m20i scanning problems
its probably set to a low DPI.......change your dpi to like 600 when scanning
Nov 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Why do my copies come out so light?
I found that I had to adjust the settings or my copies were almost illegible. Instead of copying at greyscale or black & white, try setting for color copies (even if using a black & white laser printer) and 600 dpi. It takes a few seconds longer to scan, but you get very clear copies that way.
May 01, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Black copies and black scan
sounds like you have a CCD problem or possibly a board. CCD stands for charge coupling device and its what interprets your scan original to convert it to digital form. these machines carry a 3 yr warranty. hopefully, its covered still.
hth,
razors
Jan 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
My copier stop at half way.laser light goes to the right & dont turn back.
You are not looking at th laser. If you are you will go blind. You are most likly looking at the scanning lamp. You did not say what make or kind of copier. Also, do you get a error code? Also, do you get a small part of the copy and the rest is black? If you get part of a copy and the rest is black, you have a analog copier and most likely you have a cracked or a short caued by a crack in the scanning lamp power cable.
Oct 17, 2008 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
18 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
