Question about Sharp R-520J 1200 Watts Microwave Oven
The motor stopped running. the numbers and panel/light work, but if you push start, it counts down, with no sound
  • kat242424 Nov 12, 2009
    So, would I need to order a new magnitron?
    It is an above the range microwave. Does that change anything to your diagnosis.
    Thanks for your help :-)
    The solution helper was SO HELPFUL! I went to his website and learned so much!! Thanks!
  • 11,896 Answers
Sounds like you either have a problem with the main control panel circuit or the magnetron. If it was the magnetron, then it would run but just wouldn't heat. You are looking more at control panel/board issue.
You can get parts and manual at repairclinic.com or partslect.com
Posted on Nov 12, 2009
  • Nate Stansfield
    Nate Stansfield Nov 12, 2009
    This
    is usually caused by either a bad door switch, a loose door switch
    mount (which are pretty simple problems to fix) or
    occasionally a
    problem on the control panel.
    Even though a door
    switch clicks, it may still be bad inside.
    Door switch
    or mount trouble is usually caused by slamming the door or by opening
    the
    door while it's cooking without hitting the Stop pad first.
    There are
    plastic mounts inside the microwave which hold the door switches and
    onto which the door latches lock when you close the door.
    The screws on these
    mounts may be loose. If they get too loose, the switches will not be
    activated properly.
    Sometimes it's
    a broken tab on the switch holder, allowing the switch to rotate just
    out of position.
    This tab
    can be hard to see, since it is under the
    bottom edge of the switch.
    If the switch mount is
    broken, it's usually more economical and
    safer to add a dab or two of hot glue to the mount to secure the
    switch. Let it cool for about 30 minutes before using.
    One test that sometimes
    helps is to
    gently lift up (and/or push down) on the door or handle as you try to
    start it. If it works or tries to work, then it's a door switch mount
    or
    door alignment issue.
    You can find helpful
    exploded view diagrams and order parts by entering your full model
    number
    here.
    There
    should be a "mini-manual" (tech sheet) hidden inside the unit
    behind the
    control panel or hidden on the left side behind the grille, which is
    very helpful when troubleshooting, testing, and locating
    components.
    At
    our Web site, we have a video
    available showing how to remove a typical
    over the range control panel assembly in under 5 minutes.
    If you don't find yours,
    or if you want to look at it without disassembling the oven, you can
    download it
    here.
    If you only need a
    switch, you can order a universal type
    here for $5 postpaid.
    If you think the problem
    is on the control panel,
    we repair these nationwide by mail
    for $39.95 postpaid in most cases in about a week or so with a one-year
    guarantee.
    We're
    happy to help you with free advice and we'd appreciate your thoughtful
    rating of our answer.
Emerson Microwave MW9117W. Timer Counts down and turn table stops, but continues to hum as if microwave is still running. Have to unplug to stop it. Anyone know what problem is? Thanks
Sounds like you have a ''smart board" or door switch problem, try to un plug the product, push all the 'buttons' on the control panel and then plug the product back in, if this does not correct the problem you have a component that has failed.
Jan 09, 2015 | Emerson Microwave Ovens
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
Sharp R-520J 1200 Watts Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
