Question about KitchenAid Dryers
No heat in dryer
Dryer runs but without any heat
    Problem Solver:
  • 11 Answers
Start with the simple first...
Make sure BOTH hot legs of your 220 power are active. Sometimes, one half of your circuit breaker will trip. When this happens, you will have 120 volts to your drum motor, but an open circuit to the heating coils. Just re-set your breaker by cycling it off and on again. Sometimes a loose connection where the power cord connects to the machine can melt away causing a failed connection. Please exercise caution and disconnect from live power supply before doing anything!!!
Otherwise, check for continuity of the thermal cut out fuse (in line to coils).There should be a schematic inside the machine panel.
Then proceed to check continuity through the heating coils.
Hope this helps you.
Bondo
Posted on Nov 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
Dryer drum is running but without heat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101 ..
Oct 28, 2010 | Kenmore Dryers
Kenmore gas dryer will not heat when i place clothe. runs fine without clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 28, 2010 | Kenmore 74672 Gas Dryer
My gas dryer run without heat can you help me?
heatman101
Jun 27, 2010 | Kenmore 72882 Gas Dryer
Dryer produced no hot air
many parts in the dryer can cause this however the easiest to check is you house circuit breaker or fuse. a dryer needs 240v to run the heat and if one side (120v) blows it will still run but without heat
Feb 08, 2010 | Kenmore Dryers
No heat in dryer
check your house fuses or circuit breaker.a dryer needs 240v to heat if you loose a line (120v) it will still run but without heat
Feb 06, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER not heating
Check the terminal block and make sure you're getting 220. If you only get 110, the dryer will run but without heat.
Apr 03, 2008 | Maytag PYE2300AY Electric Dryer
Open Questions:
Dryers Logo
126 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
