Question about Minolta Maxxum 7000 35mm SLR Camera
When I install the battery in my 7000i it makes a noise the screen has two lines appear but the camera will not turn on.
  • 302 Answers
I had a similar problem with my 8000i. Parts are getting scarce for these older Maxxums, but you can still get it repaired. Unless you are emotionally attached to this 7000i consider replacing it. You should be able to find another on Ebay for a decent price. You might also consider the subsequent generations which offer better AF performance. The 650xi, 700xi and 800xi are all good cameras and available on Ebay. Lighter versions like the Maxxum 70 and the XTsi are also available. The last of the film Maxxums was the single digit 7. It is generally regarded as the best of the Maxxum series, but still sells on Ebay over 150.00 typically. These subsequent models will take all your maxxum lenses and flashes. These newer models offer many other features and often less weight to carry around.
lightspiritphotography.com
Posted on Jan 01, 2010
What type of Batteries does the Minolta Maxxum 7000i take?
6 Volt Lithium photo battery
www.ebatts.com/minolta_maxxum-7000i_digital-camera_batteries_part_b-151.aspx
Oct 16, 2012 | Konica Minolta Black Minolta Maxxum 7000i...
I need a rechargable battery for my minolta dynax 7000i camera
The Minolta Dynax 7000i uses a 2CR5 battery. This is a disposable lithium battery. As far as I know, there is no rechargeable equivalent.
Mar 02, 2012 | Minolta Dynax 7000i 35mm Film Camera
No auto focus.
the gear inside is shredded at the teeth.
Jul 10, 2010 | Samsung Digimax S630 Digital Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
The flash unit for my Minolta Maxxum 7000i turns on but no "whine" of a capacitor charging. It goes back off on its on after a few seconds. Pushing the test button has no effect. Is this an owner...
Hello
Flash guns are not normally that easy to repair, and most of the guns for the Minolta 7000i are getting pretty old and parts are becoming scarce.
The first thing to check is that the batteries are good, make sure you are using rechargeable or some of the new high power AA batteries, cheap bulk buy batteries are no good for flashguns.
Second, make sure the battery contacts are nice and clean.
If you still have problems post again but with the model of the flashgun as well.
Oct 03, 2008 | Cameras
Minolta Maxxum 3200i Flash does work
Try to short out the flash and see if the flash flashes.
Remove flash from camera.
New or fresh bateries installed.
Get wire with insulation and remove both end bare to 1/4"
Turn on flash and wait until light turn green or ready.
Touch one lead to center of flash pin, touch other end to the outside(rail on the side) pin.
Flash should discharges.
atdlee@netzero.com
Jul 28, 2008 | Cameras
Monilta 7000i
ron,
send it to a camera shop,the fungus may have spread to the flex circuit under the top cover. there are no new parts for this model so finding a camera repair shop to clean it may take a few tries.
get an estimate first.
Dec 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Lines appearing on camera and images
Chwck the Samsung website -technical Support team -especially if this is a recent purchase. But generally speaking this is a no repair situation.
Jun 11, 2007 | Samsung Digimax V50 Digital Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
90 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
