Question about Fujitronic FH-797 Portable Air Conditioner
No cooling everything on air conditioner works except cooling . when it was cooling we would have water coming out of a drain on the outside which we tend to think is normal but with no cooling working no water is coming out now would the problem be the unit needs re - gassing.
  • 2 more comments
  • mama Liz Apr 26, 2008
    I dont know about the heat working we don't use it but my aircon works it comes on and shuts off I can hear it and see air blowing out of the vents but its not cold help
  • Anonymous Mar 23, 2009
    air conditioner seems like it is working fine but the air coming out is no longer cold and very little water drips from the drain tube anymore.
  • miah956 May 10, 2009
    I filled the tank with water, turned it on and kept it on for a good 3 hours or so - and it never got cool (and yes, the "cool" button was on). Not sure what to do - the instruction manual was very unclear... a lot of mispellings too.
  • miah956 May 11, 2010
    oh... and this is after i installed it for the first time. This is a brand new machine -- Miah
    Problem Solver:
  • 10 Answers
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Posted on Jan 08, 2008
6ya staff
SOURCE:
My air conditioning unit is leaking water on the ground outside. Also the air upstairs in not coming out. It's working in the basement. What could be the problem?
It is normal for an air conditioner to drain water outside.
The lack of air flow upstairs could be due to closed or blocked registers.
Aug 07, 2017 | Heating & Cooling
I tried to run my air conditioner the other day, but the house started to smell like dust and dirt. If I pull the vent off and clean in there, how far back do I need to go to get all the dirt? I tri
Not all of your question was view-able, but sounds like your drain tube may be plugged if you are getting musty smells. Inspect the drain tube for clogging (lower right of unit). Pour a glass of water over the metal fins and watch to make sure it drains correctly down and out the tube. Look outside or at the far end where it drains and be sure water comes out. If not, try a bristle brush style pipe cleaner wire to insert and clean the opening. Once its draining well, you should use a mild bleach solution and spray bottle to hose down the entire inside heat exchanger. Never put anything into/between the metal fins except cleaning fluid. Using a brush on the fins will mostly just push the dust back and compact it so the water can't dislodge it. After a good cleaning, it will help to run just the fan or heat mode for a while so the vents dry before using cooling mode.
John
Jan 23, 2015 | GE Quiet-Aire Ductless Split System Air...
The furnace is running but there is no cool air. I change my filters every month and I flushed out the water lines last month.
flushing out water lines do you mean condensate line coming off the furnace that drain to the outside. is the condensing unit outside running when u have it in cooling mode. by condensing unit I mean the unit outside that has lines that run to the inside. does that turn on when u have it in cooling. the unit outside have two components that should turn on the outdoor condenser fan and a compressor.
Aug 21, 2011 | Ruud UAKA060 Air Conditioner
My Kenmore window ac unit cools ok but makes a clicking/clacking sound while it runs. The cooling fan turns properly and it drains outside but has started to drain a little inside-it is angled to drain...
From everything you described, it sounds like more water than usual is collecting in the drip fan. Despite the unit draining out the rear drain hole. Check the drain hole to make sure it is totally clear and not partially clogged. A pipe cleaner works well to do this. Be sure to turn the unit OFF & unplug it, before working on it.
Hope this helped you and tanks for choosing FixYa.
Aug 15, 2011 | Kenmore 76100 Wall/Window Air Conditioner
I have a 6000 btu window unit. I was wanting to know how the unit drains the water. where does the water come out of the unit at? I could not find a drain hole.
No drain holes on most units that size
The water gets from the front evaporator thru
a small hole you can not see
Then it finds it's way to the outside or back on the
bottom metal pan
It is evaporated by the condensor fan
It may drain out over the rear pan lip, if
it gets alot, but no drain hole is necessary
You can angle the unit down at the outside or
rear & you can drill a small hole, but it uses the water
to cool the condenser
Aug 04, 2011 | Haier HWR08XC7 Air Conditioner
My through the wall whirlpool air conditioner has water sprinkling through where the cold air comes into the room is my air conditioner broken??
No... either the drain hole is plugged or the unit is tipped forward instead of backward...make sure that the unit outside the window is lower then the inside by just a bit... The drain holes are usually in the back outside corners and often they plug up with dirt or debris...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Whirlpool Designer ACU109PR...
Poor cooling
cold air is made by refrigeration in the air conditioner. If the unit is low on the freon charge then you have a poor exchange and poor cooling. I have gotten the units to work better by putting a little water on the outside exchange coil. by bringing the temp down on the outside coil you get a better exchange and better cooling. I used a small copper tube with about 10 real small holes in it to drizzel just a little bit of water on the outside part of the machine. the fan cools off the outside coils off and gets a better exchange bringing down the temp of the air coming out of air conditioner
May 01, 2011 | Heating & Cooling
Water not draining out the back
Humidity is where the water comes from. If humidity is low, very little if any, water.
Jun 23, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Jul 10, 2008 | Samsung AW0505M Air Conditioner
Fujitronic FH-797 Portable Air Conditioner Logo
296 people viewed this question
Top Fujitronic Heating & Cooling Experts
Marvin
Marvin
Bill Long
Are you a Fujitronic Heating and Cooling Expert? Answer questions, earn points and help others
