Question about HP OfficeJet 7110 All-In-One Thermal Printer
Replaced ink cartridges but printer does not print
Replaced ink cartridges, printer goes through process and ejects paper but there is nothing on it, does not print.
    Problem Solver:
  • 18 Answers
u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Posted on Nov 12, 2009
Printer ink cartridges full but nothing comes on the paper
Try those solution:
- Clean the head within the printer maintenance mode.
- If you filled the cartridges by yourself, make sure that you empty the cartridges of air after filling it with ink!
Mar 18, 2012 | Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Printer goes about its normal printing actions, sounds, the tray moves back and forth and it sounds and seems like its printing but then the paper comes out and nothing at all is printed on it. Both...
Make sure that the plastic part is taken off the ink cartridges. They are usually sealed with an orange, yellow, or red plastic tape-like thing over the bottom part of the cartridges.
You may also want to run a "clean head" process on the printer. This can also help if there is no plastic thing covering the ink cartridge.
Jul 09, 2011 | Lexmark X125 All-In-One InkJet Printer
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
I905D does not print
The first tip on this page should help get the ink flowing, especially if you are using a remanufactured cartridge:
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
I have found that using warm water on the paper towel helps get the ink flowing better.
Nov 18, 2008 | Canon BubbleJet i905d InkJet Printer
No ink coming from cartridges.
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
137 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
