On my Amana thermostat, the word ''battery'' is showing. I have not seen that before. I changed the three AA batteries in the console, yet ''battery'' is still showing. Any advice?
    Scholar:
  • 108 Answers
Clean the battery contacts...if they are fine then make sure the batteries you put in are new...if they are then the thermostat is simply defective....as long as it functions normally ignore the battery symbol....you will simply have no warning when the batteries are weak....change them once a year to be safe
Posted on Nov 13, 2009
How do I change AA batteries in kidde carbon monoxide alarm?
the spring is the negative end of the battery(-)
the flat section is the positive end (+)
Sep 30, 2015 | Kidde Home Security
How do I change the lithium battery in my Garrison Programmable Thermostat Model No. 52-8896-6?
The front faceplate simply pulls off - no tools required. The Garrison uses 3 AA batteries. Once you pull off the faceplate you will see where the batteries go.
Hope this helps!!
Nov 01, 2014 | Heating & Cooling
DP transport LP 6500, where do you change the battery of the monitors and why won't the belt incline?
1) Push Bottom end of Monitor to front, at slot on console, then lift monitor up and out of console.
2) Open battery door of monitor
3) Remove old batteries
4) Insert 2 AA Alkaline Bateries and close battery door
5) Press monitor into console until it snaps into place.
Sep 01, 2013 | Exercise & Fitness
Thermostat
Add a comment and describe brand, type and model of product. And what this product does. Is this a thermostat?
Also say if this is new installation or older installation
If you have Honeywell thermostat, then model number and AA battery are located on back of device. Replace battery.
Web search your model number and include .pdf in search parameter to obtain product manual, Use Ctrl+f to word-search manual for troubleshoot section. And view manual for illustrations showing location of battery.
Apr 25, 2013 | Honeywell TH5110D1022 Focus PRO 5000...
New batteries installed including 2 AA and the CR 1220. Still shows, change the battery. What is wrong
Hi
I dont know what kind og batteries you used. I suggests you ro use rechargeable Nimh natteries (AA)( more than 1500 mah) or you can check with Alkaline batteries (AA).Still the problem perists it might be a damaged power board .You have to consult a Doctor... camaera doctor..
Feb 11, 2013 | Canon PowerShot A520 Digital Camera
Getting no readings on our Trane heatpump/furnance thermostat. Checked all circuit breakers and they are on and ok. Is there an internal thermostat battery that might need to be replaced? The units are...
Most wall mounted thermostats use a single AA Alkaline battery to power the thermostat. There should be a panel or door on the thermostat housing that slides open to change the battery.
Jan 24, 2011 | Heating & Cooling
The thermostat for the main zone in my house (honeywell model RTH5100B1017) is battery powered and it blinked change the battery for a couple of daye and then went blank. I have changed the batteries twice...
  • Check any batteries and replace if needed. Ensure that you use only AA alkaline, nonrechargeable batteries.
  • 2 Check for oxidation buildup on battery contacts. Use electrical contact cleaner and carefully clean the battery contacts of any oxidation buildup.
  • 3 Reset the system switch.
  • Read more: How to Troubleshoot Honeywell Thermostats ' eHow.com http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html#ixzz17aWIl2Xt
    Dec 09, 2010 | Heating & Cooling
    My wii remotes will not show the little hand
    Synchronizing Wii Remote: Press the power button to turn on your Wii console. Remove the battery cover on the back of the remote . Change the two AA batteries. Open the door on the front of the Wii console and press the RED (SYNC) button at the same time push the RED (SYNC) button in the battery area of the remote. Thats all now have fun.
    Aug 25, 2010 | Nintendo Wii Console
    Amana thermostat, is there a battery to change?
    No. They may not be batteries. Many electronic thermostats use capacitors that are not removable. Some thermostats still use batteries but not all. Check with the user's manual of your thermostat for detailed information on use and troubleshooting.
    Good Luck! :-)
    Feb 24, 2010 | Amana Heating & Cooling
    Heating & Cooling Logo
    61 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
