Question about GE Profile JTP18 Electric Single Oven
Electronic controls only display 66666 when pressed
  • 6,784 Answers
HI. this is a major control fault here. You may be able to reverse the issue by unplugging the unit for 5 minutes. If the damage to the control board is not severe, this reset will force the control to reboot, and correct the issue. If the reset dose not produce positive results, simply replace the main control board.
If unplugging the unit is not possible, kindly, shut down the appropriate circuit beaker for five minutes.
Posted on Nov 12, 2009
Cant clear code or use oven after small power surge - stove top still works. GE web site does not have a F81 code they have an F8 and F1 which both say problem with keypad and electronic control needs to...
You didn't post model, but with a surge you probably looking at replacing the ERC. Does the manual say to unplug to reset, or check again on reset the control.
Some have this for reset, can't hurt to try.
  • Press the BAKEand BROIL HI/LO pads at the same time for 3-5 seconds until the display shows SF.
  • Press the COOKTIME and BROIL HI/LO button (on some models press Broil only, refer to your use and care manual). The display should show C. Press the button again until F shows in the display.
  • Press START to complete the change.
  • If this clears control, do it again to reset to Fahrenheit.
    This way actually resets for a error also besides temp.
    You can check the price of a control here,
    http://www.repairclinic.com/
    And you can google search for more places to shop prices.
    Mar 30, 2013 | Ovens
    I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
    The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
    See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
    "This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
    Mar 14, 2011 | Ovens
    How do i set the time on w westinghouse pgn659s wall oven?
    Instructions below.
    1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
    3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
    thank for visit.
    Oct 09, 2010 | Ovens
    Oven beeps and shows F7.
    These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
    • Press "Stop/Clear" to clear the display and stop the beeping.
    • Reprogram the oven.
    • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
    thanks.
    Sep 29, 2010 | GE JGRP17 Gas Single Oven
    We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
    Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
    F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
    Thanks
    Jul 14, 2010 | Thermador CM302U Electric Double Oven
    When you press bake it reads function not avaiable press help. the oven will not turn on but the display panel seems to be working
    Unplug the oven or turn off the circuit breaker for 30 minutes. .When it comes back on press cancel,then set the clock and try again.
    If it still fails to work you will have to replace the EOC electronic control(clock).
    Jan 03, 2010 | Jenn-Air Ovens
    Oven is beeping. Electronic controls do not respond. Error message F2 is displayed
    1. Check keypad connector for firm connection (keypad connects to control board).
    2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
    Aug 21, 2009 | Kenmore Ovens
    Touch pad on double oven shows code F7
    Electronic control has detected a fault condition. Press STOP to clear the display and stop the
    beeping. Reprogram the oven. If a fault reoccurs, record the fault number.
    Jul 07, 2009 | Ovens
    Touch pad does not work and flashed FO
    FO- the touch pad is faulty. replace the eoc(electronic oven control)
    May 17, 2009 | Kenmore Ovens
    GE Profile JTP18 Electric Single Oven Logo
    78 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
