Question about Konica Minolta magicolor 2400 Laser Printer
To turn on the printer, shows error led on - Konica Minolta magicolor 2400 Laser Printer
  • 210 Answers
Start the Konica Minolta Status application on your PC and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Posted on Nov 27, 2009
Show the error light
Hi Karthik,
Try this:-
  • Check the paper roll and probably re load it.
  • Turn the printer off.
  • Press and hold the power button and then switch the printer on.
  • Release after the first flash of LED light.
  • The printer prints a test page.
  • Turn it off and then on again and then try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Citizen CTS651 Thermal Printer
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
Printer won't print labels
Try resetting the printer:
Note: it will erase all network settings.
Turn the printer off, press and hold the GO button, turn the printer back on, continue holding the GO button for at least 10 seconds, but for fewer than 20 seconds. After the Go, Attention, and Ready LEDs turn on, release the GO button. During this process, the Attention LED will turn on, the LEDs will begin to cycle, and the unit will perform a cold reset until the printer returns to the Ready state.
NOTE: If either the Go or Ready light turn off or no LEDs turn off before the GO button is released, repeat the process.
For PCL XL error: try to reinstall the printer drivers.
Oct 11, 2009 | HP LaserJet 2550L Printer
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
All four lights flash continually on Brother 2070n printer
If there is an error that cannot be cleared by the user, the printer will show that a service call is needed by
lighting up all the LEDs as below.
c5ae79f.jpg If you see the service call indication, turn off the power switch, wait a few seconds, and then turn it
back on and try to print again.
If you cannot clear the error and see the same service call indication after turning the printer back on, call
your dealer or a Brother authorized service representative.
Aug 04, 2009 | Brother HL-2040 Laser Printer
Hp 5500 dn with 49 4C02 error
Replace the jet-direct card. don't forget to install the IP address on the new card.
Apr 14, 2009 | HP LaserJet 4350TN Printer
Canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
Dec 03, 2008 | Office Equipment & Supplies
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
179 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
