Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune waher will not wash or spin drum pisplay panel reads LR
    Top Expert:
  • Maytag Master
  • 76,846 Answers
I want u to go to the attached web page, it explains exactly what the problem is and how to fix it. Go to the link below.
http://fixitnow.com/
Posted on Nov 12, 2009
  • 1 more comment
  • yadayada
    yadayada Nov 12, 2009
    sorry wrong page loaded at the link, I will copy and paste the information
  • yadayada
    Do-It-Yourself Appliance Repair Help
    google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
    Maytag Neptune Front Loading Washer Motor Won’t Spin and LR Error Code
    function ReferThisPage779b7841ed943a9e880964fef6da376b(){var rtp;rtp = window.open(http://www.tellafriendking.com/refer/?UR...'+escape(document.URL)+'&CODE=779b7841ed943a9e880964fef6da376b&JS=1','_blank','width=350,height=530, resizable=yes, status=yes, scrollbars=yes');if((null==rtp)||'undefined'==typeof(rtp) ){alert( 'The \'tell a friend\' window was prevented from opening.\n\nPlease temporarily disable your popup blocker.');}rtp.focus();}document.write("");
    document.write("
    The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
    Either way, it means just one thing: a new motor and motor control board kit are in your future.
    Maytag Neptune Motor and Motor Control Board Upgrade Kit Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back.
    Anyway, easy job, probably a una-mugger on the world-famous SUDS-o-meter. It’s all plug n’ chug; just follow the directions that come with the new kit and you’ll be fine. Here be some words of encouragement from Liquified, a talented Senior Apprentice Appliantologist in the repair forum who recently installed this kit in his Maytag Neptune MAH5500B washer:
    Minimum tool requirements: Adjustable-head cresent wrench (8′ or smaller handle), phillips head screwdriver, utility knife.
    Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
    The instructions are pretty clear. Once you pull the front panel off, there are two braces at ~45 degree angles on the lower corners of the washer. The instructions don’t ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
    They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness – since they supply a new one – then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn’t get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
    _uacct = "UA-2732768-2";
    urchinTracker();
  • yadayada
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune reads "LR" when its supposed to spin but doesn't spin what doe this mean
HI, the (lr) represent a Motor malfunction. this is commonly caused by a faulty Motor Control Board. you can confirm by inspecting the wiring harness that connects the MCB to the main control. if the harness is in good condition, replace the MCB.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Jul 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Neptune MAH4000AWW
If there are no errors then the motor controller thinks everything is ok.
Do you hear the motor spinning?
the belt in the back may be bad or jumped off.
If you want to look for yourself open the top panel.(3 screws in top rear)
Jan 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
