Question about Sharp LC46SB54U 46 in. LCD TV
We purchased a floor model - no box or base support - even sharp doesn't have the support for us! Help!
  • jbfamily3 Nov 12, 2009
    I have a copy in pdf of the manual - no need a base and screws - sharp has a base bottom but not the supports that enter the tv nor the screws for this model. store lost base and parts and cannot find any at all!!!!
    President:
  • 1,284 Answers
Click on the following link for the ownerrs manual if thats what you are needing..
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0805212.pdf
Posted on Nov 12, 2009
I lost the 4 short screws for my sharp aquos tv stand model lc 52d62u.i need to know the exact size to replace them.
Google is your friend
This is very late (4 years) but may help someone some day. For my Sharp LC52D64U stand:
Arm to base: 4 - M6 x 35mm
TV to arm: 4 - M5 x 16mm
BTW: base model CDAI-A418WJ36 fits just as well as the original CDAI-A376WJ32 and is usually cheaper on ebay.
http://www.avsforum.com/forum/28-tweaks-do-yourself/1004261-missing-sharp-aquos-screws-help.html
Jun 21, 2016 | Sharp Televison & Video
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
Phone keeps cutting out in middle of conversation
You need to ensure that the batteries are fully charged. On the handset while talking, the phone should show how much battery charge is left.
The other thing to check is how far are you from the phone base. For example if your base is on the first floor and you are on the third floor using the handset, then you might loose the signal clarity and eventually loose the connection to the base. To ensure that you are getting enough signal on all the floor, you can purchase a range externder from the manufacturer of your phone.
Dec 17, 2011 | Uniden DECT 6.0 Cordless Phone
I need the screws to connect my tv on to the base of my sharp Aquos model number LC26DA5U. serial number 508811971 . If I knew the size of the screw would I be able to buy them at a home depot ???? Can...
Four parts stores stock the screws. Once I had a chart of the screw sizes but I'm not sure that information is helpful when going to the hardware store. If you want you can call Sharp when they open tomorrow morning 8:30 AM central time 800-be-sharp to see if someone can read the screw dimensions to you. Here are the links where they can be purchased. Compare the shipping costs to determine which store you will purchase them from. I think you need four of these screws.
Partstore http://www.partstore.com/Part/Sharp/Sharp/LC26DA5U/Sharp/Sharp/LXBZ3442CEF9/New.aspx
Encompass Parts: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6049634&smodel=LC26DA5U
Sears Parts Direct: http://www.searspartsdirect.com/partsdirect/part-number/LX-BZ3442CEF9/0057/528?pathTaken=directMatch&filterPart=&pop=flush&prst=0&shdPart=LX-BZ3442CEF9
Ued: http://www.ued.net/ued/searchResults.jsp
The part number is LX-BZ3442CEF9
Sep 20, 2011 | Sharp Televison & Video
How do I know which model of Nordic Track Exp 1000 I have? I need to get a replacement key/clip as this one is lost and the machine will not work. By the way the wife purchase one which she was told was...
When you lift up the walk deck into the storage position, on the righthand side of the machine base ( the part on the floor), there is a white sticker. The model number is very small. You will need a flashlight and you will need to lay on the floor to see it. You will see the model number starting with a NTL then the 5 diget number, then the version number is just after the dot or period, it will be only 1 number. Example NTL 09087.2
You can get the part number and even order it a iconservice.com
hope this helps
Nov 11, 2010 | Nordic Track NordicTrack Treadmill, A2550
Need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
How can I get an owners manual. purchased the
go to sharp's website, then to support then to manuals.
Mar 24, 2009 | Sharp Televison & Video
Need help troublshooting floor fan problem
This problem is caused by worn brushes, these are probably not replacable. You could replace the motor but you will have more money tied up in that then replacing the fan.
Jun 24, 2008 | Lakewood HV 18-c Floor / Box Fan
Sharp LC46SB54U 46 in. LCD TV Logo
55 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
